Will the Pentax brand hood the is designed for the 02 lens, also fit the 06 lens. I know the 06 lens has it's own special hood that is deeper I guess, but will the do just a good a job. (or can the 06 hood be used on the 02?)
This descripton also says that it will fit the 01 lens, but I don't see how that would work since the 01 doesn't have the outer threads for a hood.
PentaxWebstore.com:Lens Hood PH-SBA40.5 40.5mm Lens Hood PH-SBA40.5 40.5mm
