Today looking at some freshly planted flowers in my garden and with fine spring weather around the 04 wide angle lens sprang to my mind - with its capability to focus fairly closely and with its maximum magnification of 0,15. But wait - what does that seemingly low maximum magnification mean used with a tiny sensor like the Q7's? It means that at minimum focusing distance an object that's merely
32 millimeters wide will fill the frame with the Q7/04. That's even closer than you'll get with a 1:1 macro lens on a full frame body, and not that far away from my K5-II with its 1:1 Tamron 90mm which yields - as the size of the sensor suggests - a full frame with an object approx. 24 mm wide,
So with the 04 we already
do have a real macro lens at hand and don't have to wait for the recently announced one! ;-)
And here some spring blossom shots to prove it - some of them done at minimum focusing distance (with some exceptions I only photographed very tiny blossoms).
This will become a magnolia bloom soon (cropped at the sides):
A bunch of pink daisies (mildly cropped):
One of those pink daisies closer, at minimum focusing distance (uncropped):
An equally small and very colorful primrose (cropped):
A different type of pink daisy (very mildly cropped at left and on top):
Now let's move indoors for two final shots. First is an almost wilted tulip in its last stage of blooming (cropped):
And finally a violet, very tiny flower (about 18 mm wide, but shot at an angle here) - again taken at almost the minimum focusing distance (uncropped):
All shots taken with the Q7/04 on a tripod; a macro extension arm was used to get near to the flowers and to finely regulate the distance - nice thing about the Q7 is that it weighs very little, so it's very easy to adjust and fasten the macro setup at the wildest angles without any problems (my much heavier K5-II/90mm macro combo is not that easy to handle with the same setup). Focus was adjusted using maximum focus assist (6x on the Q7) and focus peaking. ISO 100 was used for all save the last - here I upped ISO a tiny bit to 125 to compensate for some light underexposure (it was inside and not well lit, so shutter speed was with 2 seconds already at its longest).
Hope you like them!
Phil
Reason: Spelling error; identification of flower on pic #4.
