03-18-2014, 02:33 PM   #1
littledrawe's Avatar
Adapted Lenses & Shake Reduction Settings
I'm wondering if anyone has done any experimenting with shake reduction settings and lenses originally intended for other mounts? Also is the focal length for all lenses multiplied by the 5.5X factor or is it less for lenses that started small to begin with like a 110 lens?
03-18-2014, 02:39 PM   #2
You simply need to enter the focal length that's indicated on the lens. No need for multiplying or anything like that
03-18-2014, 02:49 PM   #3
Lowell Goudge's Avatar
While Adam is correct, and focal length is focal length, irrespective of format, while not documented, I personally have noted and reported that at least for the Q, that the SR seems over active and performance and IQ are improved if you enter about 70% of the true focal length. I think this is because you hold the lens differently than you would hold a Q with a small Q lens
03-19-2014, 03:11 PM   #4
hnikesch's Avatar
+1 to the 70% - 80% of focal length for adapted lenses I did some trial and error testing and some of the info is in the adapted lens thread
03-20-2014, 06:25 AM   #5
robtcorl's Avatar
QuoteOriginally posted by hnikesch Quote
+2
I believe it was after Hans posted his test that I tried it, and my images improved.
03-20-2014, 07:42 AM   #6
Thank you for the replies folks! I'll try this out and see what I get.
03-20-2014, 04:09 PM   #7
QuoteOriginally posted by littledrawe Quote
Have fun. It is a great little camera. I am still playing, but have not tried beyond 200mm seriously yet. When the snow finally melts (yes in toronto hell has frozen over) I plan to put this on my tamron 200-500/5.6 and see what I can do
03-20-2014, 05:01 PM   #8
I have found the FL settings for SR in the Q just about right up to and including 300mm. I probably just accidentally fit the default shake profile for Pentax SR. . . I found early on that Pentax SR works best for me when I hold my cameras more casually than I would think appropriate for a given FL. For me, relaxation is the key.
Scott
03-21-2014, 03:13 AM   #9
baro-nite's Avatar
QuoteOriginally posted by snostorm Quote
I have found this also -- after reading about Lowell's experiences I did some experimenting with different settings and found that the actual focal length worked best.
03-21-2014, 04:17 AM   #10
As a curious point, how are people using the camera with K mount lenses.
I use he Q with an eye level adaptor / screen shield, holding the camera like an SLR. If you hold it using only the LCD at arms length the experience might be different
03-21-2014, 04:57 AM   #11
baro-nite's Avatar
Both methods -- with a sensor loupe and without. You might be onto something -- holding the camera at arms length might result in more rotational movement and perhaps the SR is better at some types of motion than others.
03-21-2014, 09:29 AM   #12
QuoteOriginally posted by baro-nite Quote
This is what I thought about with respect to the use of the k adaptor. I support the body and lens about this point, which is different than supporting everything from the body. This causes rotation around the adaptor, as opposed to perhaps rotation about the body, as it would be on an SLR, or with small light weight lenses
03-21-2014, 12:37 PM   #13
Hi Lowell,
I always use a loupe and hold the camera like a DSLR when using anything over about 50mm.
With the shorter lenses, without a loupe, I usually hold a lot closer than arm's length -- as close as I can while still being able to reasonably see the LCD image and the focus peaking artifacts. My eyes don't focus that close, even with my trifocals, so the LCD image is blurry, but I can see it well enough to frame the shot and i trust the peaking will give me a reasonably focused shot. I usually can brace my elbows against my body when shooting like this, so the hold is pretty stable. It's a very strange way to shoot, not really seeing a focused image, but it works reasonably well for me.
Scott
03-26-2014, 10:22 AM   #14
crewl1's Avatar
Dang, much respect because your shots are dead on, didn't know you were having trouble seeing the screen !
03-26-2014, 01:24 PM   #15
Hi Lowell,
Scott
You mean I should be shooting with a blurry display to get sharp images
Maybe when you see clearly you concentrate too much on the wrong place in the image? I'll have to try this
camera, folks, lenses, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, reduction, settings
Sensor & Shake Reduction Wingincamera Pentax K-5 10 05-14-2013 12:11 AM
M42 lens' & shake reduction Big Bob Troubleshooting and Beginner Help 11 06-14-2009 06:49 AM
Using long telephotos & Shake reduction mr.voigtlander Pentax DSLR Discussion 28 06-04-2009 11:56 PM
K10D, Shake Reduction & Tripod switch79 Pentax DSLR Discussion 28 04-19-2007 06:18 PM
Shake reduction & camera life Brew1brew Pentax DSLR Discussion 9 09-27-2006 05:58 AM
All times are GMT -7. The time now is 11:36 AM. | See also: NikonForums.com, part of our network of photo forums!
