03-23-2014, 04:47 PM   #16
geomez's Avatar
QuoteOriginally posted by pickone Quote
If it wasn't for all the sensor snobs, I wouldn't be able to afford a couple of them at $850 a piece. Bring on the bad reviews, maybe I get a few more Qs.
I'm certainly a beneficiary of Pentax's previous "flops" (just look at my sig), but as much as I like cheap gear, I'd like the company that makes and promotes these wonderful systems to survive if not thrive.
03-23-2014, 05:29 PM   #17
6BQ5's Avatar
There's always going to be trade off between size and durability. Personally, I'm ok with the Q's external size. Some heft is good since it gives you something to hold on to.
I'd rather Pentax figure out how to make the internals thinner and push the sensor back further. That would enable a larger sensor in the future.
03-23-2014, 05:59 PM   #18
calsan's Avatar
Not so! The lens has to be at the distance from the sensor it was designed for.
03-23-2014, 06:04 PM   #19
VisualDarkness's Avatar
QuoteOriginally posted by calsan Quote
Well, we would finally get alot of macro lenses to choose from.
03-23-2014, 08:19 PM   #20
calsan's Avatar
he he!
03-23-2014, 08:20 PM   #21
6BQ5's Avatar
The current lenses may not be able to accommodate the bigger spot size necessary for a larger sensor that is pushed back deeper... But a whole new line could!
03-23-2014, 08:40 PM   #22
calsan's Avatar
Oh - I follow. Buy wouldn't that be a completely different camera then? Not another mount!
03-23-2014, 08:48 PM   #23
6BQ5's Avatar
Maybe, maybe not. I would hope that the optical engineers at Pentax can figure it out. Didn't Nikon do something similar with one of their lens mounts? It's the same physical mount but the spot size can be either APS or FF sized. The camera does an automatic cropping based on the lens information.
03-23-2014, 09:09 PM   #24
QuoteOriginally posted by 6BQ5 Quote
The still have the same register distance. If you increase the distance between the mount and the sensor the lenses designed for the old one won't be able to focus to infinity. Changing flange distance changes focus.
03-23-2014, 10:08 PM   #25
geomez's Avatar
QuoteOriginally posted by VisualDarkness Quote
But what if this new theoretical Q had a larger sensor that moved forward and backward, effectively changing the flange distance to accommodate the lens?
03-23-2014, 10:23 PM   #26
Fogel70's Avatar
QuoteOriginally posted by geomez Quote
That is a way too complex design, that will end up way too expensive.
It's probably hard to find users that want to spend a lot extra on a feature like that.
03-23-2014, 10:33 PM   #27
geomez's Avatar
QuoteOriginally posted by Fogel70 Quote
Possibly, but point and shoot cameras lenses move automatically closer or further from the sensor when they're powered on and off. Is there really that big a difference from moving a sensor when you put certain lenses on and off?
03-23-2014, 10:34 PM   #28
It then has to be system capable of being as exact as about 0.01mm or better. To that it would probably make the camera bigger to housh the new system and why do it then?
03-23-2014, 10:41 PM   #29
geomez's Avatar
If it makes it bigger than it's not a good idea. I'm not an engineer, I'm an idea man.
03-23-2014, 11:03 PM   #30
Of course it could be done, but is it worth it? We now have one system for the aperture, one for focusing, one for the shutter, one for shake reduction and everytime you add something more things becomes a lot more complex. The compact cameras you talk about use the focusing unit to achieve that, not an external sensor movement one.
Adding another system for the flange distance would probably cost as much that you rather buy two different cameras for the lenses instead. It just doesn't make sense since it's easier to kill the current system and build a new one instead.
---------- Post added 03-24-14 at 07:07 AM ----------
No harm in brainstorming, that's were new great ideas come from! I bet that the Pentax engineers and the economy department have shaken their heads multiple times already this year.
camera, cameras, idea, instead, lens, lenses, mirrorless, mount, pentax, pentax q, pentax q10, pentax q7, q10, q7, samsung, sensor, system
Why doesn't anyone make a CS adapter for the Q? GibbyTheMole Pentax Q 16 05-15-2013 07:40 PM
Can Pentax make FF smaller than competition? kenyee Photographic Industry and Professionals 64 02-19-2013 05:56 PM
Pentax Q, the little camera that could. lenshoarder Pentax Q 4 01-31-2013 07:37 PM
Could/should Pentax ever make a new leaf shutter lens? TomTextura Pentax SLR Lens Discussion 4 06-12-2012 08:48 AM
Ideas on how Pentax could make a FF unique (I'll start) Quazimoto Pentax DSLR Discussion 51 02-24-2012 05:14 AM
All times are GMT -7. The time now is 03:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
