Originally posted by crewl1 Did you that manually by parsing the index thread? I will send a PM. about that.
is it feasible to continue to keep the current method, but then also maintain your index in the lens samples forum?
if someone posts a lens over there but not here, would a single index be able to show the link to both locations?
Maybe the answer is to create a thread each time a new lens appears either here or there.
The maintenance of the links for multiple places would be difficult I think.
for the purpose of clarity and so other members can understand a simple way to create indexes, i copied the content of your index, by starting a quote of the post. that gave me a way to copy your links. After all i am a lazy guy at heart.
I then copied into a text editor (word in this case) to do a sort and rearrange my manufacturer and series etc. I then pasted the content back into a new post.
For additions, it is relatively easy to manually update the lenses by watching for new threads, and then by clicking on the post number itself (upper right corner) that puts the post URL into your search bar, and you can copy and paste (with correct opening and closing syntax) into the index during an edit.
with the lens archive index, you copy the thread into the index as opposed to the individual posts.
it is all manual, but once running it only takes a few minutes per new addition to keep it up to date, now that you have done the first few hundred images and lenses. Same with the lens archive when I took it over, once i got it all up to date and structured, simple to maintain
