04-10-2014, 02:04 AM   #1
Best Q7 settings
Hi
I just get Q7 (with 01, 06, 08 lenses) and now searching for best settings for this gem. There is no much info around internet for Q7
I mean settings for everything, can you share your settings with others? Thank you!
BTW: I like this forum!
04-10-2014, 06:28 AM   #2
Lens Buying Addict
monochrome's Avatar
QuoteOriginally posted by EdGuY Quote
Hi
I'd start by reading the PF Review of the Q7. It's full of information about the camera and the effect the settings have on output. There's also a good comparison to the original Q. What you'll find is a starting point - where higher ISO begins to create unpleasant noise, where lenses begin to encounter diffraction, etc. Like a dSLR, best settings are determined situaltionally by conditions and intended image character The Q7 is quite flexible and capable for such a small camera.
What you might find is several useful combinations that meet frequent uses. These can be saved as User Modes and controlled by the front Dial.
04-10-2014, 07:16 AM   #3
Thank you! I check that out.
But if people can share what settings they use with Q7, I think I'm not the only one who is interested in them.
04-10-2014, 09:54 AM   #4
vagrant10's Avatar
I usually keep mine in spot focus select, raw+, awb - then I'll choose bold monochrome, brilliant color, user 1, or cross process using the front wheel if I'm wanting to play around a little. The nice thing about the q7 is that by pressing the info button, it's pretty easy to change settings quickly. That's about all I've done settings wise...
04-10-2014, 11:43 AM   #5
hnikesch's Avatar
On a normal sunny day without dark shadows between 10AM and 2PM with native Q lenses I use P mode with exposure comp @ -0.3 AWB, ISO 100, center spot focus and shoot .jpeg then I change the exposure compensation as required to get the exposure looking the way I want the image to look. In all other types of lighting (Bright sun with deep shadows, evening, early morning, indoors, night) I shoot RAW+ and Auto ISO. still in P mode changing the exposure compensation as required to get the exposure looking the way I want the image to look. All this is assuming I am not dealing with motion or DOF issues and that I want to control shutter speed or aperture for some reason.
04-10-2014, 12:11 PM   #6
Lens Buying Addict
monochrome's Avatar
It really is just like a dSLR
'Best' is tough to answer since the camera is so versatile and we each seem to use it in the way we like. Your best settings depend on what you think is good - and might not agree with my best settings. Like I said before, I suggest you start with simple stuff and experiment - that's the fun part anyway!!
My current starting settings - what I always start with (comes back when I PowerOn):
  • Update to most recent Firmware
  • Change default "Bright" processing to "Natural"
  • Accept standard E-dial settings in Modes
  • 01 default lens mounted (usually)
    • f/2.8 usually
  • ISO Auto 1600 Limit (usually)
  • Av - as long as shutter speed stays above 1/60, otherwise M (GB = Off)
  • Multi-Segment metering
  • Flash Off
  • AF Spot (Smallest)
    • Enable MF/Autozoom (4x) - when touching up focus with Quick Shift LCD should zoom automatically
    • I use the focus and recompose method, like with a film camera
  • Peaking On
  • Single Frame
  • AE Lock only as necessary
    • AE linked to AF point OFF
  • EV Comp centered - change as necessary
I'm at work, but I think that's all of it. Of course all of this goes out the window for special needs such as backlit subjects with Fill Flash. Then I go into INFO Screen and adjust what needs adjusting - or even into Menu.
04-10-2014, 01:25 PM   #7
i think you'll find pinholecam's real world review of the Q7 very useful for settings and using the camera (search this forum to find it). i did find his review of the original Q to help me a lot and im still using some of the suggestions he made like assigning the reversal film to one of user modes on the front weel, imo with good light it renders very nice colors:
04-10-2014, 02:09 PM   #8
WoW! I get lot of hints from you, thank you all!
This camera is really something. I'm using A7R normally, bought this for every day use as a "pocket camera" and it is much better than I expected! Only need to find good viewfinder for this prime...
04-10-2014, 09:09 PM   #9
Don't overlook the ND filter. With it you can avoid stopping down to small apertures and getting into diffraction, among other uses. It does have an "auto" setting, right? The MX-1 does.
04-11-2014, 06:16 AM   #10
hnikesch's Avatar
QuoteOriginally posted by Tony Belding Quote
No the ND filter only has ON/OFF settings, too bad Auto would have been nice
04-11-2014, 03:42 PM   #11
It would be nice to be able to map the ND toggle to a button.
04-12-2014, 05:39 AM   #12
hnikesch's Avatar
QuoteOriginally posted by Talos Quote
On the Q7 you can program it to the front quick dial
Best digital settings to emulate B&W film? kodai84 Pentax K-30 & K-50 8 12-11-2015 02:46 PM
K-7 best settings robyct96 Troubleshooting and Beginner Help 5 03-06-2014 02:44 PM
In Camera Settings for Best JPGs MrJed Pentax K-5 3 02-07-2014 04:57 PM
Optimal aperture settings for DA*300 with Q7 crewl1 Pentax Q 4 09-26-2013 05:54 AM
K-30 best image settings for portraiture andri Troubleshooting and Beginner Help 5 06-15-2013 08:07 AM
All times are GMT -7. The time now is 02:06 PM. | See also: NikonForums.com, part of our network of photo forums!
