05-15-2014, 12:33 PM - 1 Like   #1
Q 04 Toy Lens Wide: DIY Filter Ring
You may be interested in attaching a filter ring--in order to attach filters, hood, and (regular) lens cap. Removed the glass from a 30.5 mm filter and attached the ring w/ gaffer's tape.
Using gray tape it almost looks like it came this way! (And even more so if I had been really careful cutting the tape.)
PENTAX K20D  Photo
PENTAX K20D  Photo
05-15-2014, 04:32 PM   #2
Great idea for adding filter capability to the 04 wideangle. What filters have you tried? I have a pola and IR filters. should be interesting. Have fun with your Q!
thanks for sharing
barondla
05-15-2014, 07:14 PM - 1 Like   #3
dms
I did it to (1) add a PL filter, and (2) add a hood. The Q's DR is limited, and cityscapes with proper street exposure have overexposed blue sky--thus the real/pressing need for adding filter.
10-22-2015, 12:49 PM   #4
paulcote's Avatar
plus the 04 wide has an excessively long lens cap that comes with it so it adds a 0.9mm onto the width of the camera with the lens cap. For lomography, you want to be FAST so you don't really want a lens cap per se. Am thinking since the toy lenses are plastic, it makes good sense to cover them with a piece of glass and forgo the lens cap.
10-22-2015, 01:29 PM   #5
dms
I am pretty sure the toy lenses are glass--just may not be multi-coated. In any event adding filter (w/o clear overall advantage) will cause needless additional flare.
I find the 04 lens to be quite good and setting the focus/taped at roughly the hyperfocal distance most convenient. I use it most of the time--over the 01 and 02 lens.
10-22-2015, 06:03 PM   #6
paulcote's Avatar
QuoteOriginally posted by dms Quote
what do you use for a lens cap? I noticed the one that comes with it is excessively long and takes up another centimeter. I guess I could trim it.
10-22-2015, 07:54 PM   #7
dms
Look above (my thread)--you will see my Q w/ the 04 lens, and a 30.5 mm filter ring (w/glass removed) taped to the lens, and a standard lens cap (the lens cap says 30 mm inside--although I thought it was 30.5 mm also). This allows you to add a filter when desired.
I have used it for over a year, very robust (it is in my jacket pocket or backpack almost every day w/o padding), although the lens cap has gotten pushed on to the point I had to pry it off a few times.
camera, filter, lens, mirrorless, pentax q, pentax q10, pentax q7, q10, q7, tape, toy lens
Pentax Q DIY Toy Lens with Macro VisualDarkness Pentax Q 3 10-22-2013 07:52 PM
Toying with the #04 Toy lens wide (internally modified). barondla Pentax Q 16 07-20-2013 07:09 PM
For Sale - Sold: Pentax-Q body ,04 Toy Lens Wide Sliver-Surfer Sold Items 7 05-12-2013 08:04 AM
For Sale - Sold: Pentax Q 04 Wide Toy Lens blackcloudbrew Sold Items 4 04-23-2013 11:59 AM
04 toy lens wide any good? Jacos Pentax Q 14 10-25-2012 07:25 AM
All times are GMT -7. The time now is 10:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
