I cannot complain since I got one of these (C-mount len) for cheap. But at any rate, this len will not work on C-mount or D-mount (I tried C-to-D mount) since it required reaaallllly small minimal distance to CMOS sensor and you will not be able to focus, unless you are making your own adapter that REALLY really close to the sensor.
All is not lost however. I am planning to use it on Raspberry Pi camera module. That module has a CMOS sensor of 9.44 full frame crop factor and when I mount it on the module it should be able to give me 3.5*(9.44/2) - 8.0*(9.44/2) or about 16.52mm to 37.76mm of equivalent zoom on Raspberry Pi at ~ f/3.2
Picture of the beast attached, also rapsberry pi camera module, and also a sample pic of it free-lensing.
If any of you guys managed to mount it on a an adapter let me know. I am also planning to mount it on a harder plastic body cap of they are selling one for pentax Q. Otherwise it is not worth it unless you like to tinker around and instead get a wide angle cine D-mount len instead.
