06-29-2014, 03:57 PM   #1
hi
ive owned my Q for years now !!
just thought id let you know
seeing as im on here ill ask
ive still got 1.0 firmware on mine , i been meaning to do this for ages , always put it off as i hear it can cost a lot to rectify if you make a mistake .
is is worth risking as i hear it improves AF slightly which is a minor complaint id label at mine , only very minor too but any improvement welcome .
06-29-2014, 05:09 PM   #2
Mikesul's Avatar
The Q was greatly improved by the early firmware upgrades. You should do it. It is very easy if you carefully follow the simple directions found on the download site. Oh, and welcome to the Pentax Q discussion on PF. This is a very helpful and knowledgable group.
06-29-2014, 05:57 PM   #3
Welcome sebenza! Mikesul is correct about the firmware updates. Pentax greatly improved the Q system with many updates. The Q will focus much quicker and have far fewer lockups. You also get focus peaking and the ability to set focal length for image stabilization with adapted lenses.
The camera is good at helping with fw updates. If the update isn't on the SD card correctly, the camera refuses the update. Have many friends with Q's. Not a one has bricked their camera. Keep in mind that the 01 and 02 lenses also have FW updates.
Some things to watch when doing updates:
1. Absolutely freshly charged battery.
2. Pick correct update for your Q body model. Same with lenses.
3. Use empty, formatted SD card to put one FW update on at a time.
4. Don't touch camera during update.
The Q will wipe out all your custom settings. Make sure you write them down. If you have the Q set to continuous file numbering the FW usually resets to the next highest prefix number. Img100-xxxx sets to img110-xxxx.
Follow the instructions and you will be fine. Enjoy your "new" Q!
thanks
barondla
Post some pics.
06-29-2014, 07:51 PM   #4
QuoteOriginally posted by sebenza Quote
It doesn't improve the AF slightly... It improves it tremendously. Do the firmware upgrade as directed, and with a freshly charged battery, and you will be amazed by the difference in AF speed and accuracy. Plus, you'll get focus peaking, which is extremely useful.
06-30-2014, 10:12 AM   #5
well that was easy , and it was a temendous difference , like a new camera !! .
thanks
06-30-2014, 07:43 PM   #6
Mikesul's Avatar
Glad to hear you did it. Did you also update the lens firmware as suggested by Barondla?
07-03-2014, 12:26 PM   #7
no not yet i will still enjoing this upgrade yet .
camera, id, mine, mirrorless, pentax q, pentax q10, pentax q7, q10, q7
Hi Vetranquil Welcomes and Introductions 2 02-15-2013 08:16 PM
Hi-Ho, Hi-Ho, It's Off to Jail We Go Parallax General Talk 11 11-13-2012 07:44 AM
Hi TicToc1991 Welcomes and Introductions 1 07-17-2012 03:20 PM
Hi j2n2d1 Welcomes and Introductions 3 12-07-2011 08:59 PM
New Guy says Hi Colbyt Welcomes and Introductions 3 12-25-2010 06:32 PM
All times are GMT -7. The time now is 07:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
