07-11-2014, 12:33 PM   #16
boriscleto's Avatar
The link still returns an error, maybe because I'm in Canada? If I use the keywords to search I only get the Cirrus, is it the same?
Just do a search on eBay for jinfinance. Go to their store and search for Pentax Adapter Q.
07-11-2014, 12:59 PM   #17
bdery's Avatar
QuoteOriginally posted by boriscleto Quote
Done that. something must be going on, what I get is this, with no adapter:
adapter rings step rings, large format eBay Boutiques | RJ camera accessory store
When searching from eBay, their store appears empty. When searching from google, their store has two pages of items, but no adapter. I contacted them, we'll see what's going on.
07-11-2014, 02:14 PM   #18
GUB
GUB's Avatar
This is the aperture adjustable one I use.:FREE SHIPPING KIWIFOTOS Mount Adapter For PENTAX K PK LENS TO PENTAX Q Q10 PQ CAMERA APERTURE-in Lens Adapter from Electronics on Aliexpress.com
07-11-2014, 05:24 PM   #19
bdery's Avatar
The link is back to working here.
The previous question hasn't been answered. Apart from flash at high-speed, what's the gain of having the leaf shutter?
07-11-2014, 05:53 PM   #20
boriscleto's Avatar
At speeds of less than 1/2000s the electronic shutter can suffer from rolling shutter artifacts. The leaf shutter avoids these while still allowing the advantages of an electronic shutter (speeds above 1/2000s).
07-11-2014, 06:10 PM   #21
fgaudet's Avatar
And this will be more obvious with longer lenses (100mm +) which is more than likely gonna happen with an adapted lens. However, I never experienced any problem with the infamous jello effect so far and my most used lens on my Q is a 135. It will depend on what you shoot I guess.
A side note, with my no-name adapter the Q will not fire the hot shoe at all, no matter what the shutter speed is or mode I use.
07-11-2014, 09:40 PM   #22
GUB
GUB's Avatar
QuoteOriginally posted by fgaudet Quote
That is the most annoying thing about the Q -- A perfect closeup / maco camera and I can't use my ring flash on it.
07-14-2014, 09:53 AM   #23
crewl1's Avatar
Check this thread https://www.pentaxforums.com/forums/136-pentax-q/159246-definitive-manual-ext...-guidance.html
07-14-2014, 10:00 AM   #24
bdery's Avatar
Since most (all?) compact cameras lack a shutter, I assume they can suffer from this effect too?
07-14-2014, 10:25 AM   #25
boriscleto's Avatar
All cameras that use a CMOS sensor can suffer from this effect, particularly when shooting video. Just Google Rolling Shutter Jello...
07-14-2014, 10:49 AM   #26
fgaudet's Avatar
QuoteOriginally posted by crewl1 Quote
Check this thread Definitive manual external flash guidance
As the guide says (edit at the bottom) while a non-Q lens is attached and a manual flash, the flash will not fire, no matter what
07-14-2014, 12:28 PM   #27
bdery's Avatar
In fact a CMOS should be better, since all pixels are read at once, opposed to a CCD whose pixels are read line by line.
07-14-2014, 01:46 PM   #28
boriscleto's Avatar
But CCDs use a global shutter.
CCDs (charge-coupled devices) are alternatives to CMOS sensors. CCDs utilize what is referred to as global shutters, which take a snapshot representing a single point of time and therefore do not suffer from these motion artifacts.
07-15-2014, 06:03 AM   #29
bdery's Avatar
I'd like to know where that quote comes from to better understand what it means.
A CCD or CMOS takes advantage of the photoelectric effect to measure light. That physical phenomenon earned Einstein his Nobel prize and it's a phenomenon that will occur whether you like it or not. You cannot "turn off" the photoelectric effect on the pixel surface. What you can do is prevent the light from reaching the CCD, with a shutter of any form you want.
The only way to understand that quote for me, out of context, is to guess that it refers to an amplified CCD. when you turn off the amplification the current generated will be, in comparison, very small, doing the same effect as a shutter would. With some intensified CCDs, using electron tubes and a phosphor plate, you can even reverse the polarity and prevent the electrons from traveling the tube. But that's a completely different type of CCD.
07-15-2014, 06:37 AM   #30
boriscleto's Avatar
Try this...
Rolling shutter - Wikipedia, the free encyclopedia
and this...
Key differences between rolling shutter and frame (global) shutter.
How does a Global Shutter Work? | digitalbolex.com
Global & Rolling Shutters
adapter, camera, k to q adaptor, lens, mirrorless, pentax, pentax q, pentax q10, pentax q7, q10, q7, tripod
Has anyone tried Canon lenses on the Q/Q10? NeilGratton Pentax Q 14 05-31-2013 09:03 AM
has anyone tried this? slip Pentax Camera and Field Accessories 18 01-13-2011 03:55 AM
Has anyone tried this? Tony3d Pentax DSLR Discussion 9 12-17-2010 06:59 AM
Has anyone tried this TC? $89.95 Russell-Evans Pentax SLR Lens Discussion 26 10-24-2009 01:58 PM
Has anyone ever tried this photolady95 Troubleshooting and Beginner Help 17 06-07-2009 04:37 PM
All times are GMT -7. The time now is 09:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
