Originally posted by boriscleto But CCDs use a global shutter.
I'd like to know where that quote comes from to better understand what it means.
A CCD or CMOS takes advantage of the photoelectric effect to measure light. That physical phenomenon earned Einstein his Nobel prize and it's a phenomenon that will occur whether you like it or not. You cannot "turn off" the photoelectric effect on the pixel surface. What you can do is prevent the light from reaching the CCD, with a shutter of any form you want.
The only way to understand that quote for me, out of context, is to guess that it refers to an amplified CCD. when you turn off the amplification the current generated will be, in comparison, very small, doing the same effect as a shutter would. With some intensified CCDs, using electron tubes and a phosphor plate, you can even reverse the polarity and prevent the electrons from traveling the tube. But that's a completely different type of CCD.
