Originally posted by barondla CWRailman, the trains look real. Excellent construction and photography. Fascinating.
Some questions:
1. Do you ever use focus stacking for more depth of field?
2. Ever try the miniature digital filter on the Q?
3. Any plans to try the Pentax ultrawide zoom?
thanks for sharing
barondla
Thank you for your comments on the models.
No I have not tried photo stacking. Except for some contrast adjustment or size reduction to be used on my WEB site and of course using Gimp to add my watermark, I do very little PP of my images. In a similar process of registration, I have tried HDR with the in camera processing however when I zoom in on those images I find the in camera registration produces a slightly blurred image reminiscent of what the low pass filters do. Getting away from that low pass filter was the main reason I went with the K-5IIs.
I am not sure what you mean by miniature digital filters. If you are referring to the “toy” filter, yes I have but that did not produce anything I was interested in.
If someone drops one of those Pentax wide zooms for the Q into my pocket free of charge I will definitely give one a try but right now at the prices I am seeing well..............
Having said that, I should point out that when shooting this size models with my K series cameras I seldom shoot wider than 30mm because personally I do not like the perspective I get when using anything much wider than 30mm. With the Q I really like what I get with the 01 Prime. In the past when I shot 1:1 scale doll house miniatures on 35mm film I seldom used anything wider than 50mm for much the same reason. However, if I do find one of those wide Q lenses on my door step ………..
I should point out that the Q will never replace or be able to produce the same quality shots I get with the K series. It was not meant to do that. I use it in situations where it is impractical to get the K camera into. I really like the “Tonal Expansion” special effect which I think produces an image similar to a painting. In my 07/16/2014 Blog on my WEB site I showed a picture of an 2-8-8-2 locomotive that was done with that Tone Expansion. The owner of that model liked that image so much he is paying to have it printed on a canvas type surface.
Denny
