10-08-2014, 07:34 AM   #1
wildman's Avatar
A simple question
Just updated firmware to 1.13 from 1.0.
Before I updated it did not ask me to input focal length on start up and now it does.
What's the secret menu item that will turn it off at startup? I have SR turned off so far as I know.
10-08-2014, 07:43 AM   #2
Bcrary3's Avatar
What camera are you using?
10-08-2014, 07:45 AM   #3
wildman's Avatar
QuoteOriginally posted by Bcrary3 Quote
Pentax Q - the original first version.
10-08-2014, 08:03 AM   #4
Have you changed lens at all (presuming you have a Q series lens mounted)? If you don't quite have the lens clicked firmly into position, it will not recognise it and therefore ask you the focal length.
If it is a Q series lens, also check that you have the latest firmware on the lens.
10-08-2014, 09:02 AM   #5
What lens are you using? If a Q, it shouldn't be asking the FL as far as I know. Lense firmware update is a good idea to try then.
10-08-2014, 09:13 AM   #6
wildman's Avatar
I have no Q series lens' whatsoever.
I use the Q on the backend of a telescope.
Like this:
https://www.pentaxforums.com/forums/136-pentax-q/172196-lets-share-shots-q-276.html#post2963985
However in spite of this I had no problem with this when Ver 1.0 was installed.
10-08-2014, 09:55 AM   #7
Undot's Avatar
Hmm, looking at the firmware changes it seems like this was added with v1.10:
Correspond to [Adapter Q for K-mount Lenses]. How to input focal length Click here
I don't know if that can be turned off. Or how.
Possibly when turning off shake reduction, since that has to have the focal info to function.
Does it happen every single time or only when you change the connection?
10-08-2014, 10:07 AM   #8
Wildman how did you input the focal length prior to the update (if you did) ?
Out of curiosity do you use Shake Reduction? Any chance you enabled it at all with the upgrade to 1.13? Wondering if activating SR on a non-Q lens would result in this behavior...
On mine the Input Focal Length is greyed out but that is normal since I am using a Q lens.
I cannot find any other option related with this function in the menus.
Edit: Just saw the previous post with the same idea...sorry
10-08-2014, 02:17 PM   #9
dms
My Q asks when it is powered up, when I use the original Q-K adapter, whether I am in:
(i) (normal) SR on
(ii) SR off
(iii) SR on and 2 sec timer.
I believe I have latest software upgrade. BTW you can just hit OK and it will accept it (even if it is 0 mm) and be ready to take the shot.
10-08-2014, 03:06 PM   #10
when using adapted lenses, the Q will always ask for the focal length of the lens attached. you use the directional control on the back to set the focal length. the Q will remember all the focal lengths you entered and you can scroll through them later with the thumb wheel so you don't have to enter it in manually each time. It will also remember the last focal length used, so if you switch from a Q lens back to your adapted lens, it will speed up the process. this focal length info is entered into the EXIF data of your photos. it's an awesome feature for those of us who use adapted lenses regularly. hope this helps - erik
10-08-2014, 04:39 PM   #11
wildman's Avatar
QuoteOriginally posted by mamethot Quote
Never did and ver 1.00 never asked
QuoteOriginally posted by emergo Quote
See above.
Thanks quys. I think this clears it up. The difference in behavior is due to the difference in firmware.
But I can live with it if I have to. I'll just assume the upgrade gives me other improvements that are worth the additional hassle.
When it comes up all I have to do is tap the shutter release and I'm in.
Thanks much.
10-08-2014, 05:51 PM   #12
of course, it won't do it with native Q lenses as they have the circuitry within that communicates with the camera. this feature is only active with adapted lenses
camera, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
A simple question: wildman General Photography 25 07-10-2014 10:40 AM
A simple question... wildman Photographic Technique 3 10-16-2013 03:59 AM
A simple question about Ev display wildman Pentax K-5 8 01-16-2013 05:45 PM
A simple question on the Q camera. VE2CJW Pentax Q 7 01-03-2013 09:37 AM
A simple question wildman Digital Processing, Software, and Printing 13 10-20-2012 04:38 PM
All times are GMT -7. The time now is 01:51 AM. | See also: NikonForums.com, part of our network of photo forums!
