11-06-2014, 02:30 PM   #16
monochrome's Avatar
Webpage not available.
11-06-2014, 04:55 PM   #17
Done.
11-06-2014, 04:58 PM   #18
crewl1's Avatar
Done - did you know you can host a poll here too?
11-06-2014, 05:04 PM   #19
Done!
11-06-2014, 05:11 PM   #20
QuoteOriginally posted by tvdtvdtvd Quote
Completed. I think you covered the bases well. Only question I had difficulty was the last. The 01 is better than OK but not
quite perfect. A metal barrel and distance scales might make it perfect. I decided to see the list as a numerical ranking and
gave it a 4, (OK).
I agree with this.
11-06-2014, 09:54 PM   #21
done...........
11-07-2014, 01:38 AM   #22
sapporodan's Avatar
Thanks to everyone who has done the survey, I have had 60 responses already!
Its a shame I was limited to posting only 10 questions, I had about 30 I wanted to post, but maybe that would have been too much!
I just had a quick look at the results so far and..............................................Ill post up the results next week
Thanks again to everyone, it's really appreciated.
Dan
11-07-2014, 06:03 AM   #23
Done.
11-07-2014, 06:11 AM   #24
sapporodan's Avatar
QuoteOriginally posted by crewl1 Quote
Really! no I didn't, ill have to check it out.
11-07-2014, 06:38 AM   #25
aurele's Avatar
QuoteOriginally posted by lytrytyr Quote
The 02 zoom gives you f/2.8, at 24mm equivalent on the Q7, and 28mm on the Q.
indeed, but with the zoom, the Q ain't pocketable really. I was hoping for a slim 24-28mm, and sligtly faster than f2,8.
11-07-2014, 06:43 AM   #26
JayBee451's Avatar
Done
11-07-2014, 07:16 AM   #27
Heinrich Lohmann's Avatar
Done!
11-07-2014, 07:25 AM   #28
Done... :-)
11-07-2014, 07:54 AM   #29
6BQ5's Avatar
A collapsable zoom lens would be awesome but the outermost barrel diameter may become much bigger. We may end up with a case of small-body-big-lens here like the Lumix GM1.
11-07-2014, 08:08 AM   #30
QuoteOriginally posted by 6BQ5 Quote
I don't have any problem with a camera attached to the lens, instead of vise-versa, as long as I have adequate composing capabilities. In fact, I believe the Q has a significant opportunity as an alternative to the bridge cameras, since its sensor is somewhat larger and therefore should be able to provide less noise or more bit depth in the resulting pictures. Hang the Q on the end of a 16-300mm lens, or some such thing, and you'd have all the capability you need. You'd probably have to focus manually, but that is possible given enough help from the camera.
camera, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, questions, survey
Pentax Q/Q10 Quick Handbook (for Japanese people) VisualDarkness Pentax Q 4 01-12-2013 08:02 AM
DA*200 on Q, quick test baro-nite Pentax Q 25 11-25-2012 09:25 AM
Quick Review: Pixco Pentax 110 to Q Mount adaptor cjfeola Pentax Q 4 06-22-2012 05:54 AM
Pentax Q Quick Dial Smart Effect and Digital Filter mdavi Pentax Q 2 03-23-2012 02:56 AM
DA35 vs FA50, a quick image survey... FHPhotographer Pentax SLR Lens Discussion 11 08-04-2008 07:15 PM
All times are GMT -7. The time now is 11:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
