Quick, simple an' cheap from a one quart milk carton.
The relatively small area makes it effective as a diffuser
for close-ups only. The relatively large area to the right side helps soften the hard shadow thrown by the off-set flash head. Being 'flat' it packs easily in the kit bag.
