12-18-2014, 10:43 AM   #31
reh321's Avatar
QuoteOriginally posted by dms Quote
In order to carry the Q in a sports jacket pocket--the 02 is too large. Either the 01 or the 04 (wide) allow it. I use the 04 taped to yield infinity to about 4 feet to be in focus. Or the 01 and set the focus w/ the green button. I think my preference is the 04 wide (but I really like equivalent 35mm FL)--unless you are shooting at night/in doors--where the speed of the 01 wins.
Incidentally both my 04 lenses seemed best (if you want 4 feet to infinity in focus) if the focus is set at the 2nd left most mark (and it changes a lot with a small movement).
Oh--nothing about the 04 images suggest a "toy lens."
I want to be sure I understand correctly.
The 04 lens is wider (6.3mm) but slower (f/7.1) - and you feel that the image quality is OK
The 01 lens is less wide (8.5mm) but faster (f/1.9) - and image quality is better
From the pictures, the 04 lens appears to be longer physically.
Is that true?
12-18-2014, 11:07 AM   #32
dms
Yes to all except the 04 and 01 seem to be about same in length--and the 04 is quite a bit less in diameter,
Also the 04 has quite a bit more distortion--but they both have so much that you need to correct for it.
01 has more resolution and is coated so less flare--nevertheless for moderate size prints they are (effectively) similar.
12-21-2014, 03:02 PM   #33
I'd be amazed if they're completely uncoated?
It may not be a full SMC coating but there must be something, surely? The only Toy Lens I have so far is the 07, I've not been able to check as the front element is too tiny and deep-sunk to do the "hold it up to the light at an angle" trick.
I should be opening the fisheye and the telephoto on the 25th, assuming Santa's courier service is keeping up with delivery dates!
camera, cap, custom, focus, kids, lens, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, stretch, toy
Does anyone own the 08 Wide-angle zoom? Cynog Ap Brychan Pentax Q 18 02-07-2014 07:47 AM
Distortion correction on the 02 zoom GibbyTheMole Pentax Q 4 03-04-2013 06:20 PM
Sports Golfing with the Q and 02 Zoom LaurenOE Post Your Photos! 5 01-03-2013 10:14 AM
Does the 02 tip the Q forward? Docrwm Pentax Q 14 11-23-2012 12:22 PM
Will Pentax make DA version of Tokina 11-16? It's the best fast ultra-wide zoom lens. ogl Pentax News and Rumors 32 08-25-2008 09:15 AM
All times are GMT -7. The time now is 12:06 PM. | See also: NikonForums.com, part of our network of photo forums!
