12-18-2014, 09:58 AM   #1
Looking for Q RAW Lens Correction Profiles .lcp
Hello Q world...
I find myself using jpg on the Q instead of RAW, as I don't have any lens correction profiles for the Q, and the distortion and such bothers me. I know (or have been told) that LR has profiles for the Q, but I am using Rawtherapee - which can use .lcp - home made or from Adobe... Has anyone made lens correction profiles for the Q? Or do I have to make an attempt at it? I'm using 01, 02 and 06 lenses... Other than the lcp problem, I'm happy enough using Rawtherapee and gimp for my photos... Haven't found the need for corrections using my k-5 and M lenses...
Thanks....
12-18-2014, 10:44 AM   #2
dms
These are approximate values for PhotoShop Lens Correction (Filter)
01 +5
02 at 5mm +9.5 at 7mm +4 (elsewhere use linear relationship)
04 wide (about) +10 [I had a value of 9 and 11--did not refine]
Really easy to do. Just photograph a target w/ strong horizontal lines (like a window blind) making sure camera is normal to the target and level, and then open raw file in software and adjust (vary correction) till the lines are straight, and note/save the correction values.
12-18-2014, 11:53 AM   #3
02 and 06 can be got from the Adobe program. I use those. I'd also like to know how to make them as I use an 08. Fortunately it doesn't need much correcting and I currently use it without a profile.
I use Linux so am a bit more stuck.
12-18-2014, 03:13 PM   #4
narual's Avatar
Create your own Lens Profiles but the software is only for windows or mac. Time to fire up an emulator, maybe.
12-18-2014, 03:58 PM   #5
drougge's Avatar
I too use rawtherapee. Mostly I use the 01 (or something adapted). I've always thought I should get or make a profile, but for the momemt I use the simple distortion correction set to -0.067, which is usually good enough. (Same simple correction type as the photoshop filter presumably.) For the 06 it varies quite a bit, and at least sometimes simple corrections are very disappointing as I recall.
If someone makes (or makes available) proper profiles that would be lovely.
12-20-2014, 12:33 PM   #6
I keep meaning to make a few profiles, but never seem to have the time... At some point I did have the lens profile creator going under Linux/wine - I think... At least that's how I remember it!
camera, correction, lens, lens correction profiles, mirrorless, pentax q, pentax q10, pentax q7, profiles, q-s1, q10, q7, rawtherapee
Pentax q lens correction in RAW files Dijker_t Pentax Q 10 06-25-2014 07:00 AM
Lens profiles in Adobe Camera Raw gosman Pentax SLR Lens Discussion 6 03-28-2014 12:18 PM
Adobe lens profiles for Camera Raw, Photoshop CS5, Lightroom 3 knoxploration Post-Processing Articles 108 11-03-2013 12:14 PM
Creating Adobe lens correction profiles for JPGs from the RAW ones beholder3 Post-Processing Articles 3 03-28-2013 09:59 AM
New to RAW, trying to figure out workflow with lens correction... dboeren Troubleshooting and Beginner Help 11 03-25-2013 04:54 PM
All times are GMT -7. The time now is 01:34 PM. | See also: NikonForums.com, part of our network of photo forums!
