Originally posted by Kendigitize There's some heavy CA around the bright edge of the moon, but I'm not using a moon filter or anything and I think that will help.
CA are due to the "afocal setup".
"Minus violet" or "fringe killer" filter may attenuate the CA, but it's not satisfaying IMO, and it's expensive.
The setup without ocular and without prime lense (the scope as a lens with t2 adapter) is much better.
---------- Post added 01-28-15 at 06:18 PM ----------
Originally posted by crewl1 Thanks for the info. The images are very sharp.
A few other questions:
What is the resulting focal length with the crop factor on the Q7?
What is the aperture you are shooting at?
Yes, very very sharp. IMO, there is the same difference between bigma and DA300mm and between DA300mm and ED80T-CF
I tried to explane that with the number of lens in a bigma or in afocal-setup (about 20 lens or more) and only three with a triplet apo-chromatic as in ED80T-CF.
I compared hand held 100-300mm panasonic zoom VR on (crop 100%)
and ed80t-cf on tripod (crop 100%)
http://www.chassimages.com/forum/index.php/topic,217130.0/all.html
The focal lenght of the ED80T-CF is 480mm.
the
equivalent (not resulting) FF focal lengh is around 2200mm on Q7, 2700mm on Q, and only 960mm on µ4/3.
The aperture is constant : 6, enough in most cases, due to a better transmission (only 3 lenses inside).
