12-29-2014, 04:35 PM   #16
murrelet's Avatar
QuoteOriginally posted by EarlVonTapia Quote
This is off topic to your original question, but
Is that The Little Mermaid wielding two ninja swords?
Why yes it is.
12-29-2014, 04:57 PM   #17
drougge's Avatar
QuoteOriginally posted by murrelet Quote
So, if I forced a slower exposure time, perhaps using an ND filter, could that help ensure the overall light output hitting each pixel is consistent?
It should work. And if you don't have the means to take a single longer exposure you could stack a number of short exposures (where the banding will be randomly placed, one assumes).
Well, of the tube. But I have a million shots taken under such lamps -- they don't have banding like is shown here.
The mechanical shutters are usually much faster than the electronic shutter on the Q, but all mechanical focal plane shutters have this problem if the lamps are fast enough. (I would guess your shutter is in the ballpark of 1/500, call it 30 times faster. That should still be slow enough that you get some inconsistency between top and bottom on some pictures (with the same lamp), but it won't be anywhere near as noticeable. And of course often you use a slow enough shutter that the effect disappears completely.)
12-30-2014, 10:10 AM   #18
QuoteOriginally posted by drougge Quote
For my tabletop setup, I was using slow shutter speeds under such lights as I was normally shooting at ISO 100 and f/11 or f/16 for such shots. Flickering fluorescents was always something that had to be dealt with back in my film cinematography days, but never gave it a thought with stills (other than just a color temperature problem) -- guess it just hasn't come up. (Probably because those type of lights don't put out nearly enough to ever be shooting at high shutter speed without supplemental lights.)
camera, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, shutter
K30 shutter died, is this known factory fault? GixxerMKD Pentax K-30 & K-50 3 01-18-2014 09:31 PM
This my friends is the problem but what is the answer? seacapt General Talk 76 09-08-2012 02:47 AM
How common is the K5 Shutter/mirror problem Rin Pentax K-5 38 12-28-2011 05:35 PM
Is the kit 18-55mm IQ really this bad? FF problem? Phoenix_ Pentax K-5 8 07-01-2011 11:30 PM
Is this a shutter problem? (6x7 with MLU) Denverdad Pentax Medium Format 8 02-04-2010 06:50 AM
All times are GMT -7. The time now is 10:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
