01-10-2015, 10:01 AM   #1
Pentax 110 adapters?
I plan to buy adapter for Pentax Auto 110 lenses (for the 18 mm lens and, maybe, also 70 mm lens). I see that at least two types of generic adapters exists. So I would be gratefull, if someone has an could share any recommendations on this (infinity focus/past infinity focus is one thing particuraily important).
01-10-2015, 10:36 AM   #2
I've seen a couple of different names on them, but the ones I've seen (in pictures) all look exactly the same to the one I've got. Do you have any links to those you think are different?
01-10-2015, 12:06 PM   #3
pacerr's Avatar
A 110 > Q adapter should not cause infinity focus errors-- it merely adds a 17.8mm spacer between the body and lens mount surfaces to accommodate the difference in registration distance.
However, the lens itself may be miss-calibrated. That shouldn't be an issue since all adapted lenses will require manual focus anyway.
If you intend to rely on the infinity stop rather than the focus screen you could pre-calibrate the lens and place an index mark on the lens barrel. Perhaps even tape it in place for a given session.
01-10-2015, 02:05 PM   #4
Thanks for the replies!
Voila:
Kipon K2500 Pentax 110 Lens Adapter TO Pentax Q Camera | eBay
and:
Pentax 110 PTX110 Lens TO Pentax Q10 K01 Q7 A6000 Camera Adapter Thumb UP Black | eBay
I'm asking mainly, beacuse I saw quite many generic adapters for different mirrorless cameras, using which I have to set the lenses to 2-3 meters on the distance scale to have real infinity which also means meaningful shift of minimum distance that can be used (with lenses that have "infinity hard stop" corectly calibrated on K-mount cameras).
01-10-2015, 02:42 PM   #5
I have the ptx110 adapter and it works fine. A lensbaby aperture disc will slip in and allow closing the lens down for greater sharpness. Friction fits perfectly.
thanks
barondla
01-10-2015, 04:58 PM   #6
QuoteOriginally posted by barondla Quote
thanks
barondla
Yes, exactly, lensbaby discs. I have the same one (except with Fotodiox name on it). I'm sure the Kipon is fine also, but maybe those discs won't fit so perfectly if you plan on using them...
01-11-2015, 12:37 AM   #7
Thanks for the replies! They are really useful or me.
01-11-2015, 09:49 PM   #8
pacerr's Avatar
Loose Q-to-? adapter mounts
I've seen a few posts questioning loose/sloppy adapter mount rings.
I just received a Fotodiox brand PK-Q adapter that had a LOT of play in the mount. On inspection I discovered that the three small screws that hold the bayonet mount ring to the adapter were loose.
Snugging them up tight and placing a drop of thread sealer on 'em fixed the problem. There's no spring tension on this ring so over tightened screws may cause friction or binding problems when attaching or detaching the lens. Cellophane tape, or even a layer of acrylic fingernail polish, used as a shim may fix that problem as well.
02-19-2015, 04:56 AM   #9
PTX110-P/Q adapter - perfect infinity focus
I finally got the adapter and it has perfect infinity focus with my P-110 24 mm lens (setting the lens at infinity mark results in sharp images of far/infinity objects). It has Pixco brand name on the box (and the hologram). But I think the same item is sold under some other "brands" and as no name unit also (with "PTX110-P/Q" printed on them).
Thanks for all the replies!
camera, infinity, lens, mirrorless, mm, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Wanted - Acquired: Pentax 110 Lenses EdwardConde Sold Items 6 03-05-2013 01:04 AM
For Sale - Sold: Adaptall 2 PK/A adapters, Canon FD adapters NRV Shooter Sold Items 5 02-27-2013 01:55 PM
Pentax 110 battery tray mdborai Pentax Film SLR Discussion 2 01-20-2013 03:21 PM
Sony NEX 5N ordered with M42, Pentax K DA and Auto 110 adapters hinman Non-Pentax Cameras: Canon, Nikon, etc. 32 12-01-2011 03:39 PM
Something nice for our Pentax Auto 110 users: Auto 110 lens database Adam Pentax Film SLR Discussion 3 09-24-2010 06:42 AM
All times are GMT -7. The time now is 09:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
