Originally posted by UncleVanya So other than flash the Q7 / 07 combo works - you can take pictures with it etc.
I was going to ask if focus confirmation was needed to make the flash fire - this fixed focus lens might not provide that and they may have forgotten to skip it when using flash? I'm stretching for ideas here.
I did an experiment just now with my Q7. I took two pictures consecutively, with the same flash and camera settings, one with an 01 lens and one with an 8.5mm lens in a c-mount adapter.
The picture with the 01 lens set off the flash.
The picture with the adapted lens did
not set off the flash.
The manual specifies that a shutter speed of 1/13 or less must be used with a lens other than a 01, 02, or 06 lens, so I had used a speed of 1/4.
