01-22-2015, 10:27 AM   #1
enoeske's Avatar
Q-S1 + 07 = no hotshoe flash?
I can't seem to get this working with pocket wizards. Flash on or off doesn't seems to make a difference. I've gone down to 1/10 shutter to make sure its not a sync speed issue. I'm not getting any triggering out of the hotshoe.
01-22-2015, 12:33 PM   #2
UncleVanya's Avatar
Which flash? The manual for the Q-S1 seems ominous about using non-Pentax flash with it...
Pentax QS-1 Operation Manual (Page 84 of 110)
See caution...
01-22-2015, 12:43 PM   #3
enoeske's Avatar
See caution...
Just plain pocket wizards -- just need it to fire the center pin.
01-22-2015, 12:54 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by enoeske Quote
I suspect that should be OK - but that manual warning is interesting. I guess just the standard disclaimer.
01-22-2015, 12:56 PM   #5
VisualDarkness's Avatar
Have you turned flash to off in the menu?
01-22-2015, 01:02 PM   #6
enoeske's Avatar
QuoteOriginally posted by VisualDarkness Quote
Yes, Flash on or off doesn't seems to make a difference
01-22-2015, 01:04 PM   #7
I now see that you already wrote it so other than bad connection or broken units I got no good guesses.
01-22-2015, 01:15 PM   #8
I can't speak to the Q-S1, because I have a Q-7. I am using a generic flash which I still had twenty years after using it with my Pentax Super Program (my wife says I never toss things). At first I had trouble getting the flash to work. IIRC, my problem was that I had disabled the flash at the menu level. I now set the on-board flash to be disabled when it is lowered and enable the external flash at the menu level. I normally set the shutter speed to something like 1/60, solely because that is the kind of shutter speed I had to use with my film cameras.
01-22-2015, 01:36 PM   #9
I can't get the FlashQ wireless trigger to work with the Q either.
01-22-2015, 02:07 PM   #10
Wolfeye's Avatar
Are you in M mode? I think you have to be in M mode.
01-22-2015, 02:16 PM   #11
enoeske's Avatar
QuoteOriginally posted by Wolfeye Quote
Yes. M mode -- 1/8th shutter, ISO 100, f/9. Flash is set to OFF. Single shot drive mode.
01-22-2015, 02:21 PM   #12
Wolfeye's Avatar
I can only suggest turning flash on. After that I think you may have a dead hot shoe. I have the Q and the Q-remote (not made by Pentax) and it works fine, but I'll have to check settings when I get home.
01-22-2015, 08:22 PM   #13
Wolfeye's Avatar
Yep, my FlashQ works fine with my Q. Flash is off, M mode, fires fine.
I suspect the hotshoe is fried. Older flash units have a high trigger voltage which can damage newer cameras. I had two Olympus Micro 4/3 hotshoes fried, but thought that Pentax had still kept the older, more robust shoes. Apparently not.
01-23-2015, 07:45 AM   #14
QuoteOriginally posted by Steve.Ledger Quote
Steve, I have the FlashQ and it works on my Q7. Do you have the Flash set to "off" in the menu and flash speed slow enough (slower than flash-sync speed)?
01-23-2015, 08:03 AM   #15
enoeske's Avatar
Well, the hotshoe works with the 01 lens perfectly fine. Its not fried or disconnected. I can trigger the flashes without a problem.
But it doesn't work with the 07 lens (which is why its in the title)
camera, hotshoe, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Given up on old Q- is Q7/Q-S1 much improved? SteveNunez Pentax Q 39 11-06-2015 04:55 AM
A brief, unscientific comparison : Original Q vs Q-S1 6BQ5 Pentax Q 29 11-30-2014 07:21 AM
Why no silver/brown q-s1? enoeske Pentax Q 1 10-02-2014 12:01 PM
Q-S1 and K-S1 New Naming? LaurenOE General Photography 8 08-21-2014 09:36 PM
Q/Q7: Can't trigger flash via hotshoe? philzucker Pentax Q 13 02-06-2014 03:43 PM
All times are GMT -7. The time now is 10:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
