01-29-2015, 05:57 PM   #16
Phenix jc's Avatar
QuoteOriginally posted by johnmflores Quote
AH. ok. THx.
Crewl1 and his DA 300mm. Awfully sorry. (can't Edit)
01-29-2015, 11:42 PM   #17
bernall's Avatar
QuoteOriginally posted by Phenix jc Quote
Yes, I'm following you from the beginning ( ? well, more or less I guess). TY for your threads !
I should have come here earlier, but I lack time.
+1
So, is the telescope better ? More powerfull for sure (500mm), and probably better, yes. But I don't know for sure, perhaps not THAT much.
Bernall convinced me : Less is more. 3 lenses APO, a crop sensor, Q, Nikon 1, m4/3, that's it.
+1
In addition I have translated the scheme I used to explain my point of vue to convince JC.
First, the principle of digiscopying, with many lenses, often misaligned, and many resulting aberrations.
01-29-2015, 11:48 PM   #18
bernall's Avatar
and the equivalent setup with the combo PentaxQ-APO-ED-Triplet telescope (see the attached picture below).
The small number of lenses and the small size sensor limit the risk of aberration, and give an equivalent focal lenght as long as digiscopying.
Classical zoom lens or fixed focal lenght are good, but have many lens too. With APS-C or FF, it's OK. Not always with small photosites of the Q system.
---------- Post added 01-30-15 at 08:00 AM ----------
In fact, pictures are good proofs
Situation (~80m) :
Q7/ED80T-CF (reduce to 33%) :
Not the same target and not the same conditions (120m), but digiscoping is less sharp and shows more CA :
(more details here : http://www.chassimages.com/forum/index.php/topic,168569.msg4513404.html#msg4513404)
01-30-2015, 02:49 PM   #19
This is cristal clear., many thnaks for the explanation. I never did the distinguish between both systems.
Now i m just wondering if i need to add such gear to my Q,
i like birding and the long range offered by K lens on Q - let say with a 300mm - is already fantastic and provides a good reach . However here we've clearly reach another quality level
01-31-2015, 04:19 AM   #20
bernall's Avatar
QuoteOriginally posted by rafa75 Quote
This is cristal clear, many thanks for the explanation.l
Hi Rafa !
Thanks for your comment.
Now i m just wondering if i need to add such gear to my Q, (...). However here we've clearly reach another quality level
Sure, but it's a special case of use : longer is the focal length, higher is the difficulty and narrower is the field of view. Shooting is obviously more complicated due to the vibrations ...
So DA300mm keeps a lot of advantages indeed.
06-02-2015, 01:45 PM - 1 Like   #21
Phenix jc's Avatar
More pictures :
Pentax Q :
Pentax Q7 :
My set up on the right ;
On the left, an Orion 80 ED Doublet with a 4/3 reflex (= 1200mm 24x36. Nice too)
You can have a comparison with a Nikon 500/8 mirror here :
(same distance only)
https://www.pentaxforums.com/forums/136-pentax-q/288562-nikon-500-8-mirror-pentax-q-q7.html
06-02-2015, 03:35 PM   #22
reh321's Avatar
QuoteOriginally posted by bernall Quote
One of the issues is where are you going to do your shooting. Sometimes I work in our backyard, but sometimes I'm out hiking/birdwatching with my wife. In the latter case, the long lens and tripod would be a real hindrance. On US Memorial Day weekend (10 days ago), my wife and I were at Pt. Pelee National Park in Canada. We saw people with complicated setups, including tripod, but they went to just one site, and sat there, while we were hiking all over the place. It was late in their migration season, so I'm not sure that any of us actually saw anything worth photographing (although, if I'd been even with my wife instead of trailing her from trying to take a picture that didn't work out I could have grabbed a picture of a pair of courting turkeys).
06-03-2015, 09:32 AM   #23
bernall's Avatar
QuoteOriginally posted by reh321 Quote
Not heavier than a bigma or so (3.814 kg without tripod)
But the ED80T-CF is not the worse ...
crop 50% (but not with PtxQ7) :
distance about 700m
06-03-2015, 10:52 AM   #24
We must be careful saying something like this because it is not always true. When photography first started, lenses would only have one or two elements. The performance was not good and so designers had to figure out what was causing the unsharpness. Aberrations were identified and ways to solve them was sought. Each element surface was used to correct an aberration and different glass types were used for the same purpose. As designers realized the importance of each surface, the complexity and number of elements increased. With the advent of low dispersion glass, both telephoto and telescope designs improved. The two designs are strikingly similar in solving color aberrations. Telescope designs cannot use a diaphragm to reduce off axis aberrations like a telephoto lens can, so the telescope designs must be sharp wide open. Not an easy task. In general, the more lens surfaces, the more aberrations you can correct. But there is a point of diminishing return, where additional elements will not improve the image but soften it. The only way a 3 element telescope or 3 element telephoto design can perform well is with the use of exotic, modern glass. Nearly all ED telephoto lenses use more than 3 elements because they want to further the color correction with rear groups.
06-03-2015, 12:42 PM   #25
bernall's Avatar
QuoteOriginally posted by desertscape Quote
Absolutely. But in case of "large" sensor only or large aperture (f/2.8 and more). For very small sensors, near the optical axis, very few aberations are to be corrected (f/6 is not wide open).
in addition of misaligned elements
06-03-2015, 03:16 PM   #26
reh321's Avatar
I'm not sure if I'm understanding you correctly. Are you saying that a lens used on a Q will show little aberation unless it is used mostly wide open??
When I first starting adapting old lenses to my Q-7, normally using the lens stopped down two or three steps to f/5.6 (I didn't want to step it down any further because of known diffraction issues), I encountered all kinds of issues, including lots of CA. I got pictures acceptable to me only when I bought a new Sigma lens.
06-03-2015, 07:29 PM   #27
bernall's Avatar
Sorry, my answer was very short and my english very poor ...
I wanted to say that many elements are necessary to build a lens with large aperture or used on large sensors.
Q are abble to use less (good ED) elements in case of long focal lens as I show with my images and on the following diagram (#18 in the present thread)
apo, camera, crop, da, ed, lens, lenses, mirrorless, pentax, pentax q, pentax q10, pentax q7, photography, photos, powerfull, q-s1, q10, q7, q7 & telescope, results, telescope, telescope triplet apo, thread, triplet
Pentax Q7 & Digiscoping~ SteveNunez Pentax Q 37 04-20-2015 04:09 PM
Video performance Q7 & S1? SteveNunez Pentax Q 3 01-04-2015 06:32 PM
Q7 & Coronado SolarMax 60 NoRules Pentax Q 11 04-23-2014 05:47 PM
Nature Q7 & smc-f-80-200 hnikesch Post Your Photos! 4 03-07-2014 07:30 PM
Triplet falls knumbnutz Post Your Photos! 12 08-10-2009 05:25 AM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, part of our network of photo forums!
