01-29-2015, 11:48 AM - 4 Likes   #1
Phenix jc's Avatar
Q7 & Telescope Triplet Apo Ed
Hi there,
I'm an old reader, but new member. Pentaxian with the Q's only.
I open a serarate thread here as I don't want to use "Q7 & Digiscoping"
Why ? because Digiscopie means a spotting scope + a compact camera (or, say, a DSLR or an hybrid PLUS lens) = between 10 to 20 lenses.
Telescope + DSLR body, or hybrid body = ...3 lenses ! (Triplet)
Less is more
If you want to learn more about it, you have to read first half of Bernall's thread (in French) here :
Une petite config pour d
To make it short, Bernall was kinda a mentor for me with this gear.
I don't know if you have defined a specific vocabulary in English for this technic, in French we're messing around "Reflex-scopie" "Reflexoscopie" etc... (still English roots...)
Triplet is better for CA. My own Telescope is an "old" MEADE 80ED series 5000, 480mm f6, not as good as the ORION 80EDT for CA (it uses Hoya glasses, FPL-51 equivallent I think, not FPL-53), but at the same level for sharpness. And...Cheaper, used.
Once again, let's make it short : I don't think there is any better ratio Price/Quality possible for telephoto shots ! Associate a m4/3 or a Pentax Q and that's it.
Of course there are pros & cons.
No more words, just some photos, my set up included
Remember : 2250mm.
crop
400m
crop
crop
crop
More photos in my thread (in French) here :
Pentax Q7 et Lunette Astro Triplet Apo ED.
01-29-2015, 12:07 PM   #2
impressive detail...what are you using to attach the telescope to the Q?
01-29-2015, 12:33 PM   #3
bernall's Avatar
QuoteOriginally posted by Phenix jc Quote
Hi JC
Very happy to read you here ! I was impatient !
01-29-2015, 12:35 PM   #4
Phenix jc's Avatar
QuoteOriginally posted by pearsaab Quote
A simple Pentax Q => T2 adapter
Just a few bucks from China
Mine is a high end Kipon : Very bad because of the inner reflections. This is a picture :
I used cardboard to make it better : The small bright triangle is a part of the adapter without cardboard : I think everybody understand now...
Another better solution (probably) :
C mount => T2 adapter via an astronomical shop, and then Pentax Q => C mount.
These adapters are shorter and probably with a better matt black inside.
Have also a look on Bernall' Set up on the "digiscoping" thread
01-29-2015, 12:37 PM   #5
Kendigitize's Avatar
Nice pix and info. Have you seen the The "Astro-Q Club!" thread?
01-29-2015, 12:46 PM   #6
Phenix jc's Avatar
QuoteOriginally posted by bernall Quote
Hi JC
Hi Bernall,
"Give to Caesar what is Caesar's !"
Seriously, I didn't have a positive view on the Pentax Q before I read you !
01-29-2015, 12:53 PM   #7
Docrwm's Avatar
Welcome aboard! Wonderful introduction. Plusieurs très belles images.
01-29-2015, 01:04 PM   #8
Phenix jc's Avatar
QuoteOriginally posted by Kendigitize Quote
Yes, I did, but I'm not a "connaisseur". It's a thread for Bernall though.
---------- Post added 01-29-15 at 01:06 PM ----------
QuoteOriginally posted by Docrwm Quote
Merci Sir !
01-29-2015, 01:40 PM   #9
crewl1's Avatar
Hello thank you for this thread. I have seen Bernalls posts on the other thread and am interested in learning more.
I have had good results with DA *300 but this looks even better.
01-29-2015, 02:31 PM   #10
amazing photography but even more amazing with what you are using
01-29-2015, 02:49 PM   #11
Phenix jc's Avatar
QuoteOriginally posted by crewl1 Quote
Yes, I'm following you from the beginning ( ? well, more or less I guess). TY for your threads !
I should have come here earlier, but I lack time.
You have powerfull results with this combo, its's smaller, probably lighter, AND you can use a fast AF with a great IQ for short distances on an APS-C Camera. Think to that.
You do need a mobile solution with 400-600mm AF (or MF for crazy guys like me...Occasionaly) for hunt when your 2000mm+ is unusable !
The price is also to consider : My used telescope was under 400 EUR.
So, is the telescope better ? More powerfull for sure (500mm), and probably better, yes. But I don't know for sure, perhaps not THAT much.
Bernall convinced me : Less is more. 3 lenses APO, a crop sensor, Q, Nikon 1, m4/3, that's it.
---------- Post added 01-29-15 at 03:24 PM ----------
TY. As a new member I can't edit, so you have to know that you must use a 5cm tube T2 on the Telescope side as a "spacer" to reach wildlife distances (and infinity). Very common in any Astro Shop.
It's not "easy" photography, but not different than Crewl1 with its DA 300mm. (and others).
The rear LCD of the Qs is awfull. Not precise enough. MF is (a pain) not easy, but doable.
BTW all these shots are taken hand held on the tripod, most of them with the SR (yes!).
I have now an IR remote, and I don't use the SR anymore.
01-29-2015, 03:32 PM   #12
"Chapeau !"
01-29-2015, 04:30 PM   #13
johnmflores's Avatar
Great stuff! Can you explain how AF works with a telescope?
01-29-2015, 04:54 PM   #14
Phenix jc's Avatar
QuoteOriginally posted by rafa75 Quote
"Chapeau !"
Merci
QuoteOriginally posted by johnmflores Quote
TY. Read again please, I was answering to Crewl1 and its DA 300mm. A telescope + Q is purely MF and extremely powerfull : That's the point : You have to duplicate your gear with a shorter AF system (read 400-900mm) for speed and mobility.
01-29-2015, 05:19 PM   #15
Merci
AH. ok. THx.
apo, camera, crop, da, ed, lens, lenses, mirrorless, pentax, pentax q, pentax q10, pentax q7, photography, photos, powerfull, q-s1, q10, q7, q7 & telescope, results, telescope, telescope triplet apo, thread, triplet
Pentax Q7 & Digiscoping~ SteveNunez Pentax Q 37 04-20-2015 04:09 PM
Video performance Q7 & S1? SteveNunez Pentax Q 3 01-04-2015 06:32 PM
Q7 & Coronado SolarMax 60 NoRules Pentax Q 11 04-23-2014 05:47 PM
Nature Q7 & smc-f-80-200 hnikesch Post Your Photos! 4 03-07-2014 07:30 PM
Triplet falls knumbnutz Post Your Photos! 12 08-10-2009 05:25 AM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
