the best upgrade for q would be a Foveon X3 panoramic sensor that works with all the already existing lenses. this does not change the effective "megapixels". im not sure if the existing lens size image circle will support much wider sensor...but then again theres a world of cine lens out there. if it was stretched 1-2 more millimeters (whatever it takes to make the PENTAX 02 Standard Zoom become wider FOV--from 27mm start to 17mm) (noting if the image cirle of the standard zoom can even do that???)
also need live hdmi..then it becomes a movie making machine that would rival bmpcc!!!
heres the perfect name...
Q-Pan
someone should pitch that pentax get a kickstarter going....
Reason: spelling
