04-19-2015, 02:40 PM   #1
Proper aperture
Today I became aware of the following article:
Chromatic Aberration - What is it and How to Avoid it
I was very interested in this because my pictures of birds in the snow last winter using adapted zoom lenses showed visible CA. Recently I did get a new Sigma 70-300mm lens, hoping that its coatings would reduce my problem - but without having bright white snow in the background, no pictures I could take right now would test for that condition.
Anyway, beyond that, the article recommends "Stop down your aperture". My understanding is that diffraction starts becoming an issue for the Q family quite early. Other than tedious testing, is there any information available about picking an aperture that will balance out losses from more diffraction and gains from less CA?
04-19-2015, 03:31 PM   #2
QuoteOriginally posted by reh321 Quote
It's definitely tough with the Q- since its sensor looks at a very small portion of the frame at a relatively high resolution, it has a tendency to make minor axial aberrations more visible. Your best bet would be to shoot at F4 to F5.6, generally speaking. Using a modern prime should also help. The good news is that since you're only using the very center of the frame, distortion and lateral CA aren't a concern.
04-20-2015, 10:43 AM - 2 Likes   #3
The Q tries to resolve 4000/6.08/2 lp/mm = 329, whereas the Q7 tries to resolve 4000/7.6/2 = 263. The resolvable lp/mm are 400 at f4, ~280 at f5.6, 200 at f8, so you need not worry about diffraction on a Q at f4 and on a Q7 at f5.6.
04-20-2015, 11:19 AM   #4
QuoteOriginally posted by Antonio Marques Quote
Thank you! That at least gives me a starting point for future testing.
BTW - where did you get all this info from??
04-21-2015, 02:48 AM   #5
I've decided that the Q's sensor is 6.08 (x4.56), since the other figures don't make sense. The Q7's is known to be 7.6 (x5.7).
For the diffraction values, I really don't know if they're independent of every other factor, but I'm following a table that is inverse of aperture:
(Notice that the numbers for integer apertures are exact, whereas the others are rounded. It's what we do anyway for f numbers, which are really multiples of the square root of 2.)
f1 1600
f1.4 1100
f2 800
f2.8 560
f4 400
f5.6 280
f8 200
f11 140
f16 100
f22 70
f32 50
aperture, article, ca aperture, camera, diffraction, mirrorless, pentax q, pentax q10, pentax q7, pictures, q-s1, q10, q7, snow
Raindrops...until I get a proper lens EllenJ Macro Photography 11 05-20-2014 06:17 AM
First proper go with Lightzone Tsuken Digital Processing, Software, and Printing 5 04-15-2014 03:36 PM
Proper film storage LFLee Pentax Medium Format 5 03-19-2014 04:04 PM
Proper way to store backup hard drives? barondla Digital Processing, Software, and Printing 3 08-22-2013 07:03 AM
Proper Lens Hood Tonytee Pentax Camera and Field Accessories 2 05-17-2013 02:32 AM
All times are GMT -7. The time now is 11:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
