04-24-2015, 03:10 AM   #1
Polarizing filter for the Q?
I'm thinking about getting a polarizing filter for my Q mainly for landscape shots as a help for the sensor which has somewheat limited dynamic range. I used such a filters for film cameras and was happy with the results. However I'm not sure if the same results can be obtained for the really small lenses (having filter threads about 30 mm in my case). The question is if with such a small lenses the filters do not influence the image quality too much (I do not plan to buy B&W or other priced alike).
Has someone good or bad expierence with PL filters on the tiny lenses, that could be shared here?
04-24-2015, 04:00 AM   #2
max_pyne's Avatar
i have one at home.. there is not too many options for this diameter, although the 08 uses 49mm
04-24-2015, 04:03 AM   #3
QuoteOriginally posted by max_pyne Quote
I rather think of using 37 mm filter - for many lenses with the step - up ring.
04-24-2015, 08:05 AM   #4
dms
I use a PL a lot w/ my Q--mostly with the wide lens (FL equivalent of about 35mm on FF). I taped a 30.5 mm filter ring (removed glass from a filter) to the lens--and then attach hood, PL, etc. to that.
The other lenses have filter thread so easy--I occasionally use PL w/ the 01 and 02 lens. No different than any other lens as far as I found.
Exactly as you say--the PL is (most) useful on the Q, as it reduces the brightness of blue sky, which helps w/ limited DR of the Q.
BTW I used inexpensive HOYA PL (simply because I found it used in the right diameter and inexpensive). And I believe it is a linear PL.
Correction it is a 30.5 mm circular PL. Most of my other PL's are linear standard (older) Tiffens. I find linear works fine.
04-24-2015, 09:03 AM   #5
QuoteOriginally posted by dms Quote
The one thing I wonder about is how modifying incoming light waves affects the diffraction issues which affect the small-sensored Q.
04-24-2015, 10:40 AM   #6
The one I have works well, it's a Rocketfish 40.5mm and wasn't very expensive. It helps quite a bit with blown highlights. Less than $6 including shipping Amazon prime.
http://www.amazon.com/Rocketfish-RF-CP405-40-5mm-Circular-Polarizer/dp/B006VZ4Z8G
04-24-2015, 11:01 AM   #7
CWRailman's Avatar
QuoteOriginally posted by Piotrek K Quote
I never leave home without a Hoya polarizer or at the very least a ND4 filter on my Q7. First I use mine in conjunction with the built in ND filter to reduce the harsh sunlight we encounter out here in Arizona which is the home of SP100 sun tan lotion, and secondly to improve saturation of colors which are washed out by the intense sun. I value the control the polarizer gives me over the sky especially on B&W shots. I appreciate the fact that the 01, 02 and 06 lenses all use the same 40.5mm filter size. I have not really noticed any deterioration of image quality when using my polarizer but then the type of shots I am employing the Q7 for out of door is not as critical as what I am using it for indoors. (Usually when I am out riding my bicycle doing errands or on some local motorcycle trips.) As a precaution against damage to the lens, day or night, I never leave the house without some kind of filter on any of my cameras and they were the first accessories I purchased for my first Q and now use on my Q7. The ability to screw on external filters is one benefit the Q has over some other cameras.
04-24-2015, 01:45 PM   #8
Many thanks for all the answers so far!
04-24-2015, 02:10 PM   #9
I'll suggest spending less on a CP and more on a higher quality Variable ND Filter. In my experience, it's easy to find a good CP but, I have yet to find a good NDX cheap.
04-24-2015, 03:59 PM   #10
Yep I've been using a Kenko circular polariser on my Q almost since the first day. It works fine. The nice thing is that one size fits all the lenses.
04-24-2015, 07:21 PM   #11
monochrome's Avatar
I use the Pentax 40.5 CP for Q - kinda pricey I guess but what da hey.
04-26-2015, 03:25 PM   #12
Mine is stuck on and filter wrenches of this size is not common/
04-26-2015, 05:53 PM   #13
CWRailman's Avatar
QuoteOriginally posted by pickone Quote
Wrap a flat rubber band like they use for bunches of vegetables around it and then try and twist it off.
04-26-2015, 06:52 PM   #14
QuoteOriginally posted by CWRailman Quote
Thanks, that worked, I knew broccoli and asparagus were good for you. I always save these, I wrapped it in half for a tight fit.
04-28-2015, 06:55 AM   #15
Multi-coated's Avatar
Have look @ Marumi Super DHG. Very high quality less the high price. As I recall my own 40.5 Super DHG CPL was 30USD on sale. Typically the price is 50-55USD.
camera, filter, filters, lenses, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, results
Polarizing filter adapters for the Ricoh WG4? edri Pentax Compact Cameras 5 01-02-2015 02:46 AM
ND or Polarizing filter for my two lens? Newtophotos Pentax SLR Lens Discussion 7 08-31-2013 04:46 PM
Polarizing Filter for M42? Tedd05 Troubleshooting and Beginner Help 2 06-23-2013 08:25 AM
Polarizing Filter for DA 12-24 The Kurly One Pentax SLR Lens Discussion 7 10-14-2011 10:02 PM
Polarizing Filter Recommendation for 45mm lens. Swift1 Pentax Medium Format 9 11-30-2009 03:21 PM
All times are GMT -7. The time now is 10:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
