05-10-2015, 07:51 AM   #1
Pentax Adapter Q for K Mount Lens vignetting at faster speeds
I'm noticing a significant vignetting when using the genuine Pentax Adapter Q for K Mount Lens with telephoto lenses.
Up to 1/320 looks OK, but from 1/400 to 1/1000 all the pics look like old time photos (not bad, but I don't always want that).
Anybody else experience this?
05-10-2015, 08:20 AM   #2
Ummm...no. More information please.
05-10-2015, 10:17 AM   #3
panoguy's Avatar
I think he means "photos please."
05-11-2015, 06:51 AM   #4
I'll try to post some images, but it's not really necessary - talking about vignetting, strong vignetting (even on all sides) and it only occurs at speeds over 1/320 and up.
Obviously this is related to the leaf shutter in the K->Q adapter, but how? Could the shutter be defectives somehow?
05-11-2015, 07:53 AM   #5
QuoteOriginally posted by digital029art Quote
Well, it shouldn't do that -- the last thing a K-mount lens should do on a Q is vignette (especially if it is a full frame lens).
Are you using a flash? That won't work at those shutter speeds and you will get weird effects (and it shouldn't even fire at all unless you are using a separate trigger somehow). But that wouldn't cause even vignetting, so I'm assuming no flash, right? But in daylight no flash, should work fine, and if only at certain shutter speeds I guess it could be the shutter but I'm not sure that would make a vignetting pattern, sounds strange.
So, what lenses exactly are you using? Is this happening with more than one? If only one, does it work right on a non-Q K-mount camera? How are you stopping down (with the adapter ring or with an aperture ring on the lens)? Etc etc...
05-11-2015, 09:25 AM   #6
reh321's Avatar
Which flash, if any, are you using? If you are using the OBF (on-board flash), are you using it in the raised or lowered position?
05-11-2015, 09:40 AM   #7
No flash in this case, this is with long lenses 300mm, 400mm. If I expose exactly the same with Pentax K->Q w/shutter VS generic k->q adapter the vignetting is very noticeable.
05-11-2015, 09:45 AM   #8
reh321's Avatar
So you get the "vignetting" with the genuine adapter while you get a "better" picture with the generic adaptor?!
05-11-2015, 10:07 AM   #9
How are you operating the aperture? Do the lenses have aperture rings? What is the setting on the dial on the adapter?
05-12-2015, 07:31 AM   #10
QuoteOriginally posted by reh321 Quote
Yes, except for the rolling electronic shutter effect which happens frequently with long lenses.
---------- Post added 05-12-15 at 10:33 AM ----------
Right, these are MF lenses, so aperture is set on lens and I have the adapter set on L (closed).
05-12-2015, 07:48 AM   #11
Unless these same lenses are acting funny on some other body, I'd say your K-Q adapter is defective. Mine works great with a variety of long lenses and fast shutter speeds. Here's some I took with a 600mm last week:
https://www.pentaxforums.com/forums/136-pentax-q/209474-adapted-lenses-tested...ml#post3242100
I don't think the adapter can even detect when a lens is mounted -- try leaving the lens off and just watch the shutter from the front -- able to see anything funny going on? (Don't happen to have a super-slomo video rig sitting around, do ya?)
05-12-2015, 08:47 AM   #12
Thanks! I just tried shooting a sequence with no lens attached into a lamp, starting at 1/1000 and down. Results show significant vignetting, more so on the left side, worst at faster speeds. Tried two different Qs, same result. So it looks like my adapter could be decentered??
P.S. Using only the electronic shutter I get even illumination at all speeds, albeit with some horizontal lines..
05-12-2015, 08:48 AM   #13
I hope you're within the return window -- send it back, it's broken.
05-12-2015, 11:38 AM   #14
Yes I am (it's a 1 year warranty right?), my first warranty claim with the Pentax / Ricoh, hope it goes smooth!
05-12-2015, 01:05 PM   #15
Maybe not "decentered", which applies to elements in a lens . . .
. . . but most likely unevenness in the way the leaf shutter opens.
adapter, adapter q for k mount, aperture, camera, lens, lenses, mirrorless, pentax, pentax adapter, pentax q, pentax q10, pentax q7, q-s1, q10, q7, vignetting
Pentax Q Adapter for K-Mount on sale at Amazon.com drewski Pentax Price Watch 4 12-30-2014 10:45 PM
For Sale - Sold: Pentax Adapter Q for K-mount Lenses (has been sold) and Tripod Foot(Still available) Mikesul Sold Items 2 11-28-2013 04:54 PM
Help: Pentax Adapter Q for K mount lenses GXRUser Pentax Q 9 11-17-2013 09:52 PM
Adapter Q for K mount multiplication factor? Kobayashi.K Pentax Q 3 05-25-2013 02:42 PM
All times are GMT -7. The time now is 04:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
