Originally posted by 2old4toys Hi, as you have both, how does the DA 55-300mm lens adapted on a Q-7 compare with the Sigma 70-300 APO optical performance?
Thanks in advance.
Several years ago I did some backyard testing of the five 300mm K-mount lenses I have. I put a paper target at one end of our yard and then took pictures from the other end; the target was attached to a textured lawn chair, so focus peaking was very quick and {I felt} very sure. Since I did all my processing at the end, I took pictures with each camera starting with its widest apertures and ending with f/11. My one concern was that for the other four lenses, I adjusted the aperture using its aperture ring, but for the DA I had to use the adjustment built into the Pentax adapter, so aperture in its case was less precise ... however, as it turned out, that did not matter. Up to f/5.6, the Sigma 70-300 APO and DA 55-300 were basically even, and ahead of the other three. Beyond f/5.6, at apertures where I had expected diffraction to rule, the images from the Sigma improved again at f/6.3 and again at f/8 and then stayed roughly the same at the last two steps, while images from the DA leveled off at f/5.6 and stayed roughly the same for all steps beyond f/5.6. Thus, I concluded that the Sigma was marginally better beyond f/5.6.
This day was sufficiently bright that I was able take all of the pictures at f/8, incidentally.
