06-23-2015, 06:11 PM   #1
Slow read speed of Q Raw files on iPad
Hi, I usually edit Q photos on iPad, especially when I'm travelling. I connect the SD card to the iPad via camera connection kit. It takes AGES for the iPad to read the Q's raw files. Never had this problem with photos taken with other cameras. Anyone know the issue? Is it because they're DNG? I don't even want to edit the Raw files on the iPad. I take Raw+, and just want the JPEGs to show up on the iPad so I can copy them over and edit them.
Thanks.
06-23-2015, 06:34 PM   #2
retired nerd
reh321's Avatar
QuoteOriginally posted by mklives Quote
Thanks.
Reading DNG files would certainly make a difference. Looking at files created by my Q7, I see that a DNG file is roughly 20 mb, while a JPG file is typically around 2.5 mb, so when you copy a DNG file you're copying 8 times as many bytes.
06-23-2015, 07:06 PM   #3
QuoteOriginally posted by reh321 Quote
Since I'm taking Raw+Jpeg, I don't see why it doesn't just read and display the thumbnails of the Jpegs when I connect the SD card. That's what happened with previous cameras. Took a couple of seconds, whereas with the Q, it takes about 10 minutes just for the thumbnails to show up on the iPad before I even copy them over.
06-23-2015, 07:46 PM   #4
Try two options.
1. Record just RAW (DNG) and then import.
2. Record just JPG and then import.
This will inform you about which of the JPG, RAW *DNG) or RAW + JPG is taking the most time.
Could be that the version of the iPad you are using does not adequately recognise the files from the Q.
Regards
Chris
06-23-2015, 08:41 PM   #5
johnmflores's Avatar
I take RAW only and experience the same slowness. I suspect the Photos is skipping the +JPEG and going straight to the RAW when importing, so the iPad has to process a bunch of RAW files just to show you thumbnails.
I usually plan around this, starting the import/preview at the beginning of lunch and checking progress after a couple of minutes. I also use smaller cards so Photos does not have to struggle with too many photos at once.
06-23-2015, 09:14 PM   #6
Thanks, I think I'll just shoot JPEG most of the time from now on, and only shoot RAW occasionally. The Q's JPEGs are pretty good anyway.
camera, files, ipad, mirrorless, pentax q, pentax q10, pentax q7, photos, q-s1, q10, q7
Number of raw files on sd card neostyles Non-Pentax Cameras: Canon, Nikon, etc. 2 09-29-2014 05:46 PM
Pentax q lens correction in RAW files Dijker_t Pentax Q 10 06-25-2014 07:00 AM
K-3 + Mac/iPad users - help me test a fix for RAW files tempelorg Troubleshooting and Beginner Help 22 04-20-2014 06:54 AM
Is there any chance a BIOS update will fix the abysmally slow raw speed? ChopperCharles Pentax Q 16 01-29-2014 03:49 AM
DPI of raw files vs jpg files MADDSNIPER Troubleshooting and Beginner Help 2 09-14-2013 11:37 AM
All times are GMT -7. The time now is 03:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
