06-26-2015, 09:05 PM   #1
Q default jpeg Bluish tinge
Hi, I've been reviewing the default jpegs taken with the Q, and noticed that a lot of them have a dull, bluish tinge and not much warmth. Can this be changed in camera without applying a filter?
Thanks.
Bill
06-26-2015, 09:06 PM   #2
Check your custom image settings
06-26-2015, 09:24 PM   #3
aleonx3's Avatar
Check also your white balance setting..
06-27-2015, 05:15 AM   #4
Your white balance has been set for nighttime shooting (eg tungsten), and now you're shooting in daylight. The blue tinge is actually accurate (it's the blue reflection of the sky), however your brain filters that reality out. Change your white balance to daylight (or auto), or shoot in raw (you can change the setting afterwards)
---------- Post added 06-27-15 at 01:17 PM ----------
(If all the people in your indoor evening shots appear to be heavily jaundiced, it's the same problem but in reverse - ie the camera is set to daylight)
06-27-2015, 06:58 PM   #5
White balance on auto. Still a slight bluish tinge in a lot of the photos. I guess I'm used to warmer photos.
06-28-2015, 02:59 AM   #6
Then do as adam said, and check the custom image settings. Set the dial on the front to the 'dot' (and not one of the night numbers), then image->icon in top left. It may be set to something odd (or there may be a setting you prefer)
07-04-2015, 04:22 PM   #7
Shoot RAW.
You have a very capable miniature DSLM in your hands. It's not a PnS camera or phone cam
07-17-2015, 04:41 PM   #8
Mothballs's Avatar
Question; Are you shooting with the Q lenses or adapted lenses?
If adapted, and you're using a cheaper adapter, check that the inside isn't high gloss finish. If it is, figure out a way to make it not glossy.
Other than that, check white balance, etc. I still need to fiddle with mine to try and get as much out of it as I can...
As it stands for my camera, I've mostly just been shooting the B&W mode; everythings way sharper, I think it only uses one colour channel for its processing.
balance, camera, change, daylight, default, default jpeg, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, tinge
Raw + jpeg versus embedded jpeg cpk Pentax DSLR Discussion 20 12-23-2014 08:44 AM
Nature A tinge of purple...... eaglem Post Your Photos! 14 02-23-2014 06:27 PM
Pentax Q RAW vs JPEG daveproctor Pentax Q 9 02-08-2012 04:19 PM
Nature White Rose with a Tinge eaglem Post Your Photos! 2 06-19-2010 04:59 AM
Too bluish.. how to set it right? silverelantra Post Your Photos! 5 04-07-2008 07:16 PM
All times are GMT -7. The time now is 06:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
