07-05-2015, 10:53 AM   #1
pacerr's Avatar
Fotodiox adptr repair
I have a Fotodiox PK/AF-PQ adapter (with the 'pod shoe and aperture control ring) which had a stuck adapter control ring. On close inspection the adapter ring was noted to be cocked and the ball bearing in the detente notch sector was visible.
Loosening and re-tightening the three screws in the face of the mount allowed the ring to re-seat properly. Note: a JIS cross point driver is called for here. If not available, try a very narrow straight slot driver.
The larger straight slot screw in the ring is not a factor; it merely positions the ring in a slot in the barrel. (Replacing it with a longer screw might allow the control ring to be locked at a given position. I didn't try that.)
adapter, camera, control, driver, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, screw, slot
New Fotodiox K-Q adapter crewl1 Pentax Q 17 01-28-2015 04:44 PM
????fotodiox???? pdophoto General Talk 3 07-31-2013 01:26 PM
Hello, I bought the new WU-1a adptr pats73fan Troubleshooting and Beginner Help 8 09-19-2012 06:26 AM
All times are GMT -7. The time now is 05:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
