09-12-2015, 03:31 AM   #1
BigMackCam's Avatar
Perspective distortion with lenses on Q7
I have some questions regarding lenses in general on the Q7...
I understand that the small sensor size reduces the field of view, a result of the 4.7x crop factor. But - is the perspective distortion (in terms of extension / compression) the same when I use a lens on my Q7 versus my K3? And whether yes or no,why?
I assume the answer is yes because the optics are the optics, and once situated at the accurate distance from the sensor by the K to Q adapter, they will perform in just the same way. So, for portraits, I would still use a short tele for compression, but would have to back up somewhat to capture the subject within the field of view - yes?
Which leads me to another question...
Does a 25mm C-mount lens exhibit roughly the same perspective distortion characteristics as a 28mm K-mount lens on the Q7?
I'm trying to understand this so I can judge the usefulness of certain focal length lenses in relation the subject matter I want to shoot.
Thanks in advance
09-12-2015, 06:00 AM   #2
Perspective distortion and "compression" only depend on field of view, they have nothing to do with focal length. So, if you use the exact same lens one time on Q7 and one time on K3, perspective distortion will be different. Due to different crop factors the field of view is different - you have to counter this by "zooming with your feet" and presto - your image looks more compressed on the Q7 than on the K3. That is, if you use the exact same lens on both.
If you adapt both to the Q7, then yes.
09-12-2015, 06:39 AM   #3
25mm x 4.7 = 117.5mm in full frame equivalent
28mm x 4.7 = 131.6mm ""
c-mount is mainly used for cctv for sensors from 1/2 inch to 1 inch (16mm diagonal)
because they are used for surveillance light transmission is more important than overall resolving power (its why they have really wide apertures)
on the Q7 expect softer edges and lower overall sharpness but plenty of bokeh when using a $25 c-mount lens
09-12-2015, 06:44 AM   #4
Compression being a function of the lens is actually an illusion -- the effect is entirely caused by distance to subject and the lens or camera don't matter at all as they do not "create" it. (Farther away=more "compression") In other words, if you shoot something with a long lens, and the same thing from the same distance with a wider lens, and then crop & magnify the wide shot to show the view of the long shot, they will look identical in terms of compression. So the effect is entirely determined by how far away from your subject you are standing.
09-12-2015, 07:00 AM   #5
audiobomber's Avatar
Agree, 100%. In fact I did this a few years ago because I was skeptical. I cropped a wide angle to the same FOV as a long lens and confirmed; perspective is solely determined by subject distance.
09-12-2015, 09:24 AM   #6
Understanding Depth of Field in Photography
09-16-2015, 01:48 AM   #7
BigMackCam's Avatar
Fascinating. I'll have to try that when I get back to the UK (and my gear!). It sounds wrong, but I take your word on it
So... If I use an adapted K mount lens on my Q7 and frame the shot for the same field of view I'd see with that same lens on my K3 (meaning I'd have to stand much farther from the subject), I'd see a greater compression of perspective, as the distance from lens to subject is greater. Have I understood that correctly?
09-16-2015, 07:37 AM   #8
reh321's Avatar
Yes, if I use on my Q7 the 50mm lens that was kitted with the Super Program I bought in 1984, the resulting image will look the same as one I would have taken with that Super Program using a 235mm lens.
09-16-2015, 04:41 PM   #9
QuoteOriginally posted by reh321 Quote
You would also need to equalize apertures for that, to equalize DOF; e.g. f2.8 on the Q7 would need f13 on the Super Program.
09-21-2015, 07:48 AM   #10
would make a great combo to shoot kite surfers with
camera, distortion, lenses, mirrorless, pentax q, pentax q10, pentax q7, perspective, q-s1, q10, q7
wanted: DA 15 perspective distortion examples slip Pentax SLR Lens Discussion 23 07-31-2015 06:53 AM
Comparison of the 03 fisheye on Q and Q7 and Q7 with third party raw converter Altglas Pentax Q 14 02-02-2015 10:59 PM
Perspective Distortion Example ChristianRock General Photography 8 01-28-2015 05:29 AM
Perspective: An example on focal length, subject distances and perspective correction carrrlangas Photographic Technique 4 09-26-2014 09:02 AM
How to fix RAW distortion for Q7 hongning Pentax Q 4 01-31-2014 09:43 PM
All times are GMT -7. The time now is 08:56 AM. | See also: NikonForums.com, part of our network of photo forums!
