09-23-2015, 11:48 PM   #1
Suleeto's Avatar
So.... what happens when...
So... what happens when I mount THIS on the Q7:
What's the crop factor on the Q7 and the Q-S1 again? This is a 500mm prime lol
09-24-2015, 12:25 AM   #2
4.6x. If you manage to lock focus, that'll be some pretty long reach!
09-24-2015, 12:26 AM   #3
max_pyne's Avatar
you'll need to buy a steady tripod :-)
the crop is around x 4.6
09-24-2015, 12:51 AM   #4
Na Horuk's Avatar
QuoteOriginally posted by Suleeto Quote
You mean.. what happens when you mount the Q7 on THAT
I've seen some Q with adapted telephoto before. Always interesting, but you never know about the results until you try. Use a lens hood and a steady tripod, try it out in bright sunlight. Super telephoto
I think this could be the same lens:
https://www.pentaxforums.com/userreviews/quantaray-500mm-f8-f32.html
09-24-2015, 12:58 AM   #5
Suleeto's Avatar
I have a steady tripod.... and a remote. And a K to Q adapter on its way from China.
2,300mm effectively LOL. Hmmm. Well why not.
---------- Post added 09-24-15 at 12:59 AM ----------
And I get that it isn't truly 2300 LOL
09-24-2015, 01:05 AM   #6
max_pyne's Avatar
yep you will only have the FOV of a 2300mm lens
09-24-2015, 05:01 AM - 1 Like   #7
Be prepared for exceptionally sh*tty results
That lens isn't even very good on its own.
09-24-2015, 07:36 AM   #8
I have been unimpressed with the 500mm presets Suleeto, While I wouldn't be as dismissive as Giklab (and the quality of these varies) I tend to agree that the results will be at best modest! For me that jump from the typical f6.3 of the 400mm presets to the f8 of the 500mm's is a bigger factor than it would nominally seem to be: focussing is a jump harder and results IME tend to be inferior to the 400's. With either, at this sort of ultra extreme telephoto, you will need every trick in the book to get the best out of it: bean bags on a wall or concrete pillar, sandbag/weight on top, mirror lock up, timer, remote release, focus bracketing... all very tedious, you will find that even eg following the movement of the moon is a PITA.
You should check out some of the results posted in this adapted lenses on Q thread. Like working with teleconverters it is the best lenses that produce the best results. However there are quite a number of surprisingly good results with lenses that are not considered so great. I can guess that a big part of that is the crop (which is effectively what is going on) is concentrated on the centre of the optic where the IQ is usually best.
And I would suggest trying good 200's first like the takumars. With the crop factor that's still an ultra telephoto 920mm equivalent. Way faster at f3.5 or f4 gives you stopping down lee way. And focus etc an order of magnitude easier.
2000mm ++ ???- get a telescope!!
09-24-2015, 08:47 AM   #9
CWRailman's Avatar
If I take what you are asking literally, what will happen is that the lens will rip the Q out of your hands and head downwardly till it meets the first flat surface where it will land with a resounding crash resulting in a sickening feeling in you stomach. It might be gooder to mount the Q onto that beast. What happens after that depends on many variables.
09-24-2015, 09:35 AM - 1 Like   #10
pacerr's Avatar
It's do-able. The CZ-500. A 6 lb/2.8 Kg lens.
09-24-2015, 04:07 PM   #11
It will be 4.6 times as bad as it was already.
camera, lol, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
What Happens When You REALLY Tick Me Off... magkelly General Talk 5 11-18-2014 12:53 PM
What Happens When Your Images Are Out Of Focus? wtlwdwgn Photographic Technique 6 04-22-2014 08:15 PM
Machinery This is what happens when a landscape photographer goes to NASCAR nomadkng Post Your Photos! 9 03-07-2014 01:40 AM
So what happens when the Millionth post happens? interested_observer General Talk 17 04-21-2010 11:57 AM
What happens when I'm bored... codiac2600 Post Your Photos! 20 11-02-2007 02:09 AM
All times are GMT -7. The time now is 09:30 PM. | See also: NikonForums.com, part of our network of photo forums!
