Show Printable Version 33 Likes Search this Thread
01-26-2016, 01:02 PM   #136
reh321's Avatar
QuoteOriginally posted by patarok Quote
honestly?
OK:
I also like the idea of the EVF...but why the hell not place it under the hotshoe, leave the pop-up flash where it is and just design the body of the next Q a little bit like the (looking only on the form of the Body, and not the placement of the flash i found it very appealing. <i bought one for my son>
>> Pentax Optio i-10..?
and BTW:
a Viewfinder placed in the middle directly under the hotshoe, would make it look more like a professional camera that it is, or could be, instead a box of cigarettes...
When thinking about such a small camera, you have to be realistic about use of space; you cannot cram everything into that case. One very reasonable alternative is to remove the flash. I have not used that flash in the past year - in fact, that camera does so well in low light situations that I have seldom used any flash with it - and the honest truth is that such a small flash can make very little contribution to a picture. Pentax was willing to sacrifice the flash for their top-of-the-line cameras - the K-3ii doesn't have one and apparently the K-1 (or whatever the FF is called) won't have one either - so sacrificing it to get the utility of an EVF is certainly a reasonable option. Right now it has the ambiance of the range-finder cameras, like those made by Leica, which dominated the camera landscape back in the day, and in those days the only cameras with built-in-flash were those marketed to amateurs. I'm not sure that is a bad model to look back to for inspiration.
Yes, there are other alternatives. They could put a 1/2-inch hump on it to house the EVF and design that hump to echo the design of the K-3ii and K-1 (or whatever the FF is called). That comes with its own cost though. A hump like that would severely reduce the camera's "pocket-ability", and I'm not convinced that would be a good trade-off. The software company which provided my first employment had the slogan "form follows function", and I believe that is a very good guide. I kind of doubt many will buy this camera because they confuse it for a "professional" camera, but I fear some will refrain from buying it if it becomes more awkward to handle.
01-26-2016, 01:10 PM   #137
Nilnoc's Avatar
Tilt and touch screen please; no EVF
Here’s a differing opinion on EVF. YMMV. And obviously does for some other Q users.
In late 2014 I bought two Q-S1 bodies and the 01, 02, 06 and 08 lenses for my wife and I to travel with. I did this after years of taking Pentax DSLR bodies and lenses on many overseas trips. We got older and the cameras got heavier. A schlepp around Istanbul finally did it for us.
One year and several trips later, I’m very happy with the portability and image quality of the Q’s. My wife less so. A telephoto shooter, she uses the 06 exclusively and just isn’t comfortable with the body-lens-controls combination. For Christmas I got her a Canon SX50, and she loves the lightweight 50 x zoom. For myself, I got a Canon G7x as an always with me in a belt case camera.
For a future Q, I don’t want the body to get much bigger or heavier. Size is the critical value point for me. There are plenty of larger choices on the market that Ricoh cannot compete well with.
After using the touch enabled tilt-screen on the small Canon G7x, I would love to see the same added to the Q. It would facilitate taking the low angle shots I love to take with the Q-S1 sitting on the Manfrotto MP1-BK tripod I keep permanently attached to the Q. You can keep it permanently attached because, uniquely, the Q’s battery and card access is from the sides. HDR and multiple exposures are possible with the this tripod.
Having a touch screen is really great for quick menu changes and setting the focus point.
As a DSLR user, I know all about viewfinders. I don’t want one on my future Q.
If Ricoh tried to add an EVF to the Q, I believe the result would be either a much larger camera or a ridiculously small and unusable EVF. If Ricoh wanted to make a detachable EVF that you could add to the hotshot like Canon has for its G3x, that would be the way to go.
01-26-2016, 11:32 PM - 1 Like   #138
bluefoam's Avatar
QuoteOriginally posted by Nilnoc Quote
Size is the critical value point for me....
Understood
...After using the touch enabled tilt-screen on the small Canon G7x, I would love to see the same added to the Q...
But you do understand that it makes the camera bigger...
...with the Q-S1 sitting on the Manfrotto MP1-BK tripod I keep permanently attached to the Q.
... I thought size was the critical value point...?
...If Ricoh tried to add an EVF to the Q, I believe the result would be either a much larger camera
much larger? as large as an articulating screen and additional tripod... I'm not disagreeing, just thing your points don't make allot of sense to me.
One of the big selling points for me is the physical controls. It is old-school and gives a creative bent to the Q that many other cameras lack. If I wanted an iPod style camera, I'd get the Nikon J1, with no controls. If Pentax do put a touch screen on the Q, I hope it is just for menu options rather than camera control.
01-27-2016, 01:32 AM   #139
Nilnoc's Avatar
QuoteOriginally posted by bluefoam Quote
[With EVF] much larger? as large as an articulating screen and additional tripod... I'm not disagreeing, just thing your points don't make allot of sense to me.
Let me clarify. I want to see a tilt-screen on the future Q. Not a fully articulated screen. Take a look at the Q-S1 and the Canon Powershot G7x on the Camera Size Comparison site. The body of the tilt-screen Canon without lens protrusion is actually thinner than the Q. A tilt screen doesn't have to add thickness. Also, the Canon has a full set of physical buttons and dials that allow the user to turn off the touch screen and still have full control of the camera. User choice.
Check out the tiny Manfrotto tripod I use. It's the MP1-BK and when folded adds a hair over 1/4 inch to the height of the Q and weighs 1 ounce. With it attached, my Q is still light and tiny. YMMV.
I get that there are people who really want an EVF on a future Q. I'm not one of them.
01-27-2016, 02:16 AM   #140
bluefoam's Avatar
I'm just being pedantic, ignore me... I don't necessarily want an EVF, but they do need to find a much better way to allow viewfinding, the current screen is mostly invisible to me much of the time.
I'd prefer a high res screen that is viewable in sunlight. Touch Screen is fine once I also have my physical controls. Articulating screen (whether limited or fully articulating) is not a priority for me.... and of course Pentax should listen to me!!!
01-27-2016, 12:57 PM   #141
Unlike Fuji which depends of feedback from users and Pros to refine existing products and design new ones, I have never heard or seen any indication of Pentax listening to anyone. Several times in this interview, Fuji execs note that changes to a product were made based on shooters feedback and how they depend on such feedback from their committed users.
Going Pro: We interview Fujifilm execs in Tokyo: Digital Photography Review
01-27-2016, 01:57 PM - 2 Likes   #142
johnmflores's Avatar
QuoteOriginally posted by CWRailman Quote
That's not entirely true. Ricoh removed the "Ricoh" logo from the back of the K-3 II because of complaints from Pentaxicans.
So there is that. Fussing over the stuff most important to great photos....
01-27-2016, 05:23 PM   #143
patarok's Avatar
You are sure, you are on the right forum? fujiforumsDOTcom???
No, honestly: look:
Full Frame- Market Launch 2015 - RIAC Community
Than FYI: Some companies have contracts with persons which read forums and news for them to gain feedback about what users want, expect or like.
And as you missed the timespan to have a word on what we may see in a FF DSLR, you may want to take your chances for:
Full-Frame Lenses Wishlist - RIAC Community
spare yourself sophistic argumenting against the wishes or expectations of others and just post which lenses you would like to see.
As you may be able to imagine, nobody who evaluates such a wishlist for RICOH will read sophistic arguments on why fuji is better or why the guy who posted before is a totall silly bloke... just not interesting.
if you want to take part, just let us know which lenses you want to see.
FYIA, "http://community.us.ricoh-imaging.com" is a forum that is run by RICOH Imaging directly...
01-27-2016, 07:04 PM - 1 Like   #144
monochrome's Avatar
Ricoh solicits opinion and feedback from many, many users.
01-27-2016, 09:28 PM   #145
No, honestly: look:
I've never heard of this RIAC thing before. It appears to be well-hidden, user hostile, and under-developed. Also, there's no Q section.
01-28-2016, 12:14 AM   #146
That RIAC effort seems stillborn.
Anyway, even if Ricoh scoured this forum for Q feedback, they'd be completely overwhelmed by the range of opinions here. From 'don't change a thing' to 'it needs a 1" sensor' everything has been proposed.
Probably the only thing we all agree on is better battery life.
01-28-2016, 01:15 AM   #147
Probably we all agree with same size / form factor (but not as Q-S1), same control layout, better res screen, better battery life, better sensor.
I think that nobody would say no to an EVF if nothing else is changed (size, flash, layout)
But personnaly what I would like is more prime lens!
- 18,5 mm f1.4
- 3 mm f1.8
- retractable 5-15mm f2.8 constant
01-28-2016, 01:27 AM   #148
Sorry, but even something as innocuous as an EVF has its detractors. :-(
01-28-2016, 05:16 AM   #149
QuoteOriginally posted by eyeswideshut Quote
This is why I've suggested multiple Q models with different price points, form factors and feature sets.
However... Realistically, the Q doesn't seem destined to become a major product line for Pentax, or at least not any time soon. Their situation is different from Olympus or Fujifilm, where mirrorless cameras are the mainstay of their business.
01-28-2016, 06:57 AM   #150
Banned
No, honestly: look:
On the full frame. In June they where looking for specs to put in a camera that should launch in october
bigma, camera, focus, high-iso, k-3, lens, lenses, mirrorless, pentax, pentax news, pentax q, pentax q10, pentax q7, pentax rumors, phase, phase detection, pixels, profile, q-s1, q10, q7, sensor
Rumor: Pentax FF new Limited lenses coming soon? Stavri Pentax News and Rumors 249 09-27-2015 10:40 AM
New Pentax leaf shutter 645 medium format lenses coming soon i83N Pentax News and Rumors 66 10-03-2014 08:03 AM
New soon-to-be Q owner Soul_Est Welcomes and Introductions 4 06-05-2013 12:21 AM
First signs of upcoming Pentax K-3 appearing... JohnBee Pentax News and Rumors 183 09-06-2012 08:20 AM
K20D will be replaced very soon? (Signs of..) RiceHigh Pentax News and Rumors 127 09-17-2008 01:16 AM
All times are GMT -7. The time now is 01:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
