buy the original K-mount adapter and a 40mm XS... bokeh and shallow DoF "en masse"...
no offense here, but:
there are a lot of mini tripods that will fit into a breast/shirt pocket...bean or rice bags also do the trick sometimes. But as i said, use either an adapter with a cool lens on or buy old video lenses and an according adapter.. I like the results
and, talking about the BC function:
as it only "computes" DoF it will have problems when the algorithm "recognizes" a multitude of objects at the same focus plane and multiple objects with nearly the same geometry in front and behind the object you are focusing at.
conclusion regarding the issue:
I guess it only works acceptable if the main object you are focusing on heavily contrasts with the backround in size, geometry and somehow in color(and or texture if you wish so...)
