12-03-2015, 11:12 AM   #1
vega's Avatar
My Q's Memory Card Tray Wont Lock
Today when i took my memory card out of my Q all was good... But when i went to put back in the lock wouldnt work thus making the card unreadable. Is there a way to remedy this? Right now i stuck a tissue in there to keep down when i close the tray seems to be an ok fix but not permanent.
12-03-2015, 12:07 PM - 1 Like   #2
blackcloudbrew's Avatar
This happened on my Q7 and it required an expensive repair. No, I don't think there is a fix other than service.
12-08-2015, 11:26 AM   #3
Ontarian50's Avatar
This came up earlier this year on this forum, but the problem is common to all SD type cameras.
It's quite typical for a tiny piece of plastic from the SD card to break off and get stuck in the lock/release mechanism of the camera - or the plastic bit gets stuck behind the contacts at the end of the card unit, and won't allow the card to go all the way in.
If you have great dexterity, or know someone who does, you can shine light inside the card slot and look for the plastic bit - easier if it's blue - harder if it's black.
Once you see it, it is sometimes possible to poke it free (have the battery out of the camera before attempting any of this, BTW) and shake it out.
Sometimes the bit is just so jammed in there, the camera has to come apart and the card unit dealt with separately.
camera, card, lock, memory, memory card tray, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, tray
Sony 94Mb/s memory card: $12.49 Adam Pentax Price Watch 10 05-05-2014 04:19 AM
K5 Foibles (?): Memory card, shake reduction, mode select lock-out button AstroDave Pentax K-5 19 05-17-2011 12:58 PM
My computer won't read my memory card Pål Jensen Pentax Camera and Field Accessories 7 07-29-2009 11:32 AM
a memory card Q socal Troubleshooting and Beginner Help 13 05-28-2009 02:34 PM
All times are GMT -7. The time now is 07:12 PM. | See also: NikonForums.com, part of our network of photo forums!
