Originally posted by Dev_Komatsu A while back I read online (it may even have been in here) that if you remove the memory card before removing the battery it fixes the problem. And it does.
I tried this, it worked, and I thought it was a nice tip.
In fact, it wasn't.
Because it works, weither the memory card is there or not.
And it works, with a fully loaded battery.
Then you can insert or remove the battery for a short period of time, and you keep the date setting (Q & Q7 for me). OK.*
I
think that the fully loaded battery gives enough power to the camera (the internal battery of the camera?) for a short period of time, so the camera is able to keep the setting in memory.
But during a shooting session, if I change an almost dry battery with a new one, it doesn't work, and I have to set the date. (already with the Q and now with the Q7).
(and same thing at home, naturally)
*This doesn't work with every camera, because, I think, it depends of the "health" of the camera : Is that camera able to "borrow" some power to a fully loaded battery, or not ? (that is the question)
Please, check, and confirm, or not.
