01-21-2016, 01:00 AM   #1
bluefoam's Avatar
Q - losing date/time setting
Every time I turn on the camera it asks me to set the time & date... This has been happening for a couple of years, but I realised that it is actually stopping me from using the camera.
Is there an internal battery that is drained or is it a software issue? Should I try a firmware change? is it down to how the memory cards are formatted? I'm really lost & I'd appreciate any advice...
01-21-2016, 01:23 AM - 2 Likes   #2
Sandy Hancock's Avatar
It happens with my Q7 every time I change the battery. Irritating, but not terminal.
01-21-2016, 02:35 AM - 1 Like   #3
Its probably an internal button cell battery that is empty. I don't know if its easily replaceable.
01-21-2016, 03:41 AM   #4
bluefoam's Avatar
Thanks for the feedback guys.
I agree that it might be a cell battery. I've found a repair shop that will be cheap, so I'll drop it in over the weekend and let you know how I get on.
www.repairingcamera.com does exactly what it says on the tin...
01-21-2016, 05:11 AM   #5
tromboads's Avatar
Yeah mine does that. Every time I change the battery. annoying, but no super big deal.
01-21-2016, 05:36 AM   #6
dlh
The problem described isn't the result of changing the camera function battery - there's another battery inside somewhere that's responsible for maintaining settings regardless of camera function battery changes. The memory used for retaining those settings is contained in CMOS low-voltage semiconductors, same as the BIOS in your computer. When that internal battery loses its oomph, you'll start noticing symptoms analogous to Alzheimer's. Make sure when you have the internal battery replaced you don't do anything to screw up your camera warranty, and that the people who do the surgery know what they're doing with respect to the brand of camera you're getting fixed.
01-21-2016, 05:54 AM - 1 Like   #7
bluefoam's Avatar
QuoteOriginally posted by dlh Quote
These guys are old school Indian repair people. They are low tech, but actually generally do a very good job. They work on much more complex equoipment than my Q. Even if they do it up, they'll find a way to make it right... It comes from a culture of repair & value... they aren't highly sophisticated, but neither are they bound by silly union rules... I'm almost 23% sure they'll do a great job
01-21-2016, 07:20 AM   #8
Marketplace Reseller
dcshooter's Avatar
Every single Q series camera I have (3 of them) has this problem. Apparently the CMOS battery they used is underspecced.
01-21-2016, 07:22 AM   #9
Lens Buying Addict
monochrome's Avatar
All of mine too. I just bypass it and ignore the EXIF.
01-21-2016, 08:57 AM   #10
I have two of the Q and three of the Q7.
All but two of the Q7 now make me reset the time.
As a result, the clocks on these Q's are the most accurate of all my camera clocks,
since the other ones drift off over the months,
and I can't be bothered to correct them.
01-21-2016, 11:03 AM   #11
This happens to my sisters Q10 and keeps her from using it too. It hasn't happened to mine yet. I never could figure out what the issue was but now I know. Really unfortunate this problem hasn't been addressed.
01-21-2016, 12:07 PM   #12
reh321's Avatar
QuoteOriginally posted by TedW Quote
My Q-7 and K-30 have exactly the same problem - if I leave the main battery out for several hours (I don't have an exact measurement), the camera forgets the current date/time.
01-22-2016, 04:53 AM   #13
bluefoam's Avatar
QuoteOriginally posted by keithlester Quote
This will always happen if you don't use your camera much and have to charge the battery before every use. The simple solution is to have spare batteries and swap in a newly charged one before you use the camera. There is no faulty internal battery in your Q. There is no point in dismantling your Q to fix the problem. Get out and use your Q every day. It's meant to be an every day fun camera and is super small and compact o it truly will go just out anywhere. If you do that, you will stop having this minor irritation. How do I know all this? It used to happen to me, but now it doesn't. I've taken my own advice.
... Eh no... Thanks for putting in all the effort to type that. But no, you are wrong. Shame.
01-22-2016, 07:28 AM   #14
Heinrich Lohmann's Avatar
We have an original Q, Q10, Q7 and a Q S1, none of them loose their date when changing batteries. We make sure that there is always a charged battery in the camera (we have about 6 spares) My understanding is that there is NO secondary battery in the camera but a sort of capacitor that keeps things going while one change the battery. If you leave the battery out too long the capacitor looses it's charge and you will have to reset things.
01-22-2016, 08:10 AM   #15
dcshooter's Avatar
Willing to place a wager on that?
Because I am more than willing to open one of my Qs up right now and take a picture of the CMOS battery for you to show you how very wrong you are.
battery, camera, cmos, ebay, experience, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7, time
Original Q: Date and Time resets every time I charge the battery? Senduy Pentax Q 3 12-29-2014 12:47 AM
help! pentax K-M requires adjust date time all time carl zeiss Pentax DSLR Discussion 9 10-05-2012 07:27 PM
DPOF setting/ time and date stamp PentaxKX-2011 Troubleshooting and Beginner Help 3 01-19-2011 09:00 AM
Losing Date/Time? sigma2398 Pentax DSLR Discussion 1 11-26-2010 03:34 AM
K20D Problem with setting date and time gubo Pentax DSLR Discussion 1 02-21-2009 09:32 AM
All times are GMT -7. The time now is 05:12 PM. | See also: NikonForums.com, part of our network of photo forums!
