01-29-2016, 05:10 AM   #1
Erich_H's Avatar
Original Q - Sensor mechanically "stuck" ...
Did a quick scan of the threads, and did not find anything like this:
Last night I used my original Q. No problems. Put it on a shelf and left it until this morning.
When I tried to turn it on, I got the SR/focal length setting screen, as normal.
I OK'd my 2,8mm and briefly got the viewfinder-display. Then it turns itself off.
Repeated this half a dozen times, same result. Put a new battery in the corpse.
Same result. Tried my 01 lens. Same result.
Finally I looked into the Q with the lens removed.
The sensor (normally moving freely for SR) is "stuck" in one position towards the side.
I know it's not "comme il faut" to do this, but when I try to move the sensor with a pin,
it just goes back to the same position. Put the camera in a sock and thumped it in my palm.
Checked the sensor and it was in the other corner. Turned it on and got a blurry unfocused display.
I've managed to take two blurry pictures. And it's stuck, again.
Anybody know anything about this? Two pics attached: before & after...
Thanks/Erik
And boy, am I glad I have two unused Q's in their original boxes...
01-29-2016, 08:25 AM   #2
johnmflores's Avatar
Some SR systems position the sensor using electromagnets. So if you are having a problem with power, the sensor might appear off-kilter. Just a guess..
02-01-2016, 05:26 AM   #3
Erich_H's Avatar
Fault fixed!!
Sunday (yesterday) I bought a can of electronic contact cleaner, poured (when I say "pour", I mean spray, sorry for the flippancy...) it into the Q, and let it dry out...
Result: Yesss, it's working...
The vignetting to the left is due to two causes:
1) the lens is a CS lens built for 1/3" sensors
2) I didn't mount it in the exact middle of the body cap - clumsy clumsy
This has the vignetting cropped out
The fault probably was because of some oxidation on some contact points in the Q gut. Which isn't surprising considering that the camera is 4,5 years old and having been in my pocket, thrown on rocks and being out in the snow, etc, etc...
So, now I'm happy again....
Thanks/Erik
02-01-2016, 05:51 AM   #4
BigMackCam's Avatar
QuoteOriginally posted by Erich_H Quote
I bought a can of electronic contact cleaner, poured it into the Q, and let it dry out...
Don't try this at home, kids!
02-01-2016, 06:17 AM   #5
Erich_H's Avatar
It's dead, so what could make it worse...
As the camera was bricked, more or less, my options were:
Sending it off for repair, probably more costly than the current price on Ebay
Dismantling the body and praying I'd find what's wrong with it
Or do what I did
So: Do try this at home, kids!
I'd be more wary of thumping it in the sock in my palm.
I admit - it was panic...
Thanks/Erik
And also, having two new original Q:s in their boxes helped with the courage, I admit ...
camera, lens, mirrorless, pentax q, pentax q10, pentax q7, position, q-s1, q10, q7, result, sensor, stuck sensor
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
K5 Focus gets "stuck" narual Troubleshooting and Beginner Help 5 08-12-2014 11:39 AM
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
K5 mirror "stuck up" or "flop"? jpzk Pentax K-5 6 09-09-2011 07:20 PM
All times are GMT -7. The time now is 01:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
