04-26-2016, 03:57 PM   #16
BigMackCam's Avatar
QuoteOriginally posted by Triggrhaapi Quote
...but the big problem I have with the 02 is it's mediocrity
With respect, I'd have to disagree. I'm very happy with my 02 (I own the 01 prime and 06 zoom also, and use various K-mount lenses with the Q-for-K-mount adapter). For best results, I stop mine down a couple of notches from wide open, but then I find the IQ more than satisfactory. Perhaps it's copy variation?
04-26-2016, 04:06 PM   #17
Like I said, I have been able to take perfectly lovely photos with it, it's just not mind blowing in any particular way. It's not razor sharp and distortion free, it's also not terrible in any way either. It's just a kit lens.
---------- Post added 04-26-16 at 04:09 PM ----------
For example.
04-26-2016, 04:20 PM   #18
BigMackCam's Avatar
That I would agree with It's certainly not mind-blowing - though I find it sharp enough that a gentle tweak in post processing (Lightroom and/or Google Nik Sharpener Pro 3) yields sharpness as good as that from the 06. Distortion is pretty much irrelevant if you're doing any kind of post-processing, too. I think it's way above mediocre... but that's just my personal view. Like I said, maybe I got lucky with mine
04-28-2016, 11:29 AM   #19
CWRailman's Avatar
If you’ve followed these threads for a while it become apparent that those of us using the Q7 are getting more favorable results from the 02 lens than those using the Q or Q10. This leads me to believe that the 02 was specifically designed to work with the 1.7 sensor and when that was not available for the early Q’s then it failed to perform well when coupled to the smaller sensor. When I had a Q a Q10 and the Q7 here I found the 02 churned out better images when used with the Q7. At least that was my findings and I had several 02’s here at the same time with both performing the same.
04-29-2016, 06:31 AM   #20
Regardless of the size of sensor you use it on,
the 02 performs noticeably worse at the tele end,
and at any focal length at a close focus distance.
It looks better on the Q7 because the bigger 12MP sensor
is less demanding than the smaller 12MP sensor
in the "crop sensor" (original) Q and Q10.
04-29-2016, 03:51 PM   #21
I do want to upgrade to the Q7 soon. Now that I have an 08 on the way, I will probably do that next.
body, camera, kit, lens, lenses, matter, mirrorless, olympus, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, review, sensor, shoe, time
Pentax Q7 + 01 Prime vs MX-1 (or other premium compact)? luftfluss Pentax Q 11 11-15-2014 08:48 AM
Mx-1 quality/landscapes pentaxian_tmb Pentax Compact Cameras 6 08-26-2014 11:46 PM
Pentax Q7 vs MX-1 = same CMos ?!?! geo444 Pentax Q 18 09-25-2013 04:56 AM
Q/Q10 vs. Q7 - image quality kshapero Pentax Q 1 06-19-2013 07:38 AM
40mm 2.8 vs 50mm 1.4 -- image quality filmamigo Pentax SLR Lens Discussion 5 10-25-2007 12:39 PM
All times are GMT -7. The time now is 10:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
