Originally posted by hoffo Guess you missed the part where I said my spare one was exhibiting the same problem. It was not inside the camera. I also have only left it maybe a month or two at most. I've left my pentax oem battery in it longer than that and it's older than both wasabi batteries and is still perfect. Plus if you take the battery out of the Q for a long time you risk a failed capacitor which stores the time and date info which is a common problem as you can read on this forum.
You have warned us of your experience. You can draw your lessons from that, and each of us can draw his/her own lessons. I don't see any reason for anything beyond that. My own practice is to rotate batteries in/out of my Q-7 on a weekly basis, because I don't like to leave any battery in any device too long, but as I said, you should go with whatever works for you.
