09-23-2016, 01:31 PM   #16
rlg118's Avatar
FastStone will convert these at full size. It huffed and puffed a bit, and showed "Not Responding" intermittently, but it did finish. Bit depth is 24, though. I specified changing color depth to 8 bits, but... I don't know. The JPGs are actually larger than the DNGs.
IrfanView has an option "Try to load embedded preview image if possible" under Plugins. It was checked. After clearing that, it loads them at full size. And it will convert the 24-bit color to 8.
Talk about jumping through flaming hoops.
09-23-2016, 01:41 PM   #17
Na Horuk's Avatar
Ah yes, things get super complicated once you dive in! Then there is color space (should be set to the same one in camera as well as all the software and export, usually sRGB), camera color profile, and so on.
09-23-2016, 01:58 PM   #18
rlg118's Avatar
Maybe I'll just shoot JPGs with the Q7, and leave the DNGs to the K50. Photography is supposed to be fun.
09-25-2016, 12:50 PM   #19
rlg118's Avatar
The Plot Sickens
Yesterday I switched to shooting JPGs, as I said, and they worked fine.
Today, I decided to go to RAW+, and I found that the "reduced-resolution image data" in the DNGs, instead of being 1920 x 1440, now matches the full-size data.
I swear I can hear the theme to The Twilight Zone starting to echo through my brain.
09-26-2016, 03:47 AM   #20
You can always try Pentax Digital Camera Utility on your Q DNG's (free software for Pentax DSLR's). It gives very good color and quite good details (set Sharpness to Fine Sharpness if it will not be default setting), so you can eventually develop all RAW files from SD card to jpg's in a batch mode and it is always possible to edit them further. I found also auto white balance of PDCU very good.
camera, faststone, mirrorless, options, pentax q, pentax q10, pentax q7, q-s1, q10, q7, rawtherapee, size, software
Software for correcting nonlinear lens distortion peterh337 Digital Processing, Software, and Printing 3 08-09-2015 03:54 PM
Any idea what is up with this lens? (Distortion city) Mothballs Pentax SLR Lens Discussion 9 05-21-2015 08:33 AM
Lens Distortion in Portraiture wolfiegirl Photographic Technique 16 11-21-2011 02:58 PM
freeware photoshop lens distortion plugins Nass Digital Processing, Software, and Printing 6 03-01-2010 12:56 AM
Automatic lens distortion correction example PentaxPoke Pentax SLR Lens Discussion 6 02-03-2009 05:39 PM
All times are GMT -7. The time now is 09:56 PM. | See also: NikonForums.com, part of our network of photo forums!
