Originally posted by keithlester You don't need a circular polariser with the Q. A linear polariser works perfectly. But use what you have.
Yes, a linear polarizer will work just as well on a Q.
The only reason we have "circular" polarizers is for cameras that use semi-silvered, or semi-transparent surfaces that can block polarized light. The old Canon FTb needed a circular polarizer because a semi-transparent surface in the focusing screen siphoned light off to the meter cell. Spinning a regular linear polarizer on that camera (and others that used that oddball system at the time) caused the meter needle to go up and down without a change in brightness.
Since the Spotmatic at that time read directly off the focusing screen, without any semi-transparent parts, a regular "linear" polarizer worked just fine.
When autofocus came along, semi-silvered mirrors siphoned light off to the focus module in the base of the camera for AF. A linear polarizer turned the wrong way would shut off the focusing.
The solution was again the "circular" polarizer, which is really just a regular polarizer with an extra layer behind the polarizing film to re-randomize the alignment of the photons.
The unfortunate thing is the term "circular" since most of the darn things are round anyway. Perhaps in theory a linear polarizer might be of better quality since it has only one layer, not two. But all the top-grade circular polarizers I've seen work just fine.
This is a long way around stating that since the Q is simply a lens in front of a sensor, there's no semi-transparent surfaces in use. So there's no need for a circular polarizer's extra abilities, but it will work just fine all the same.
