Originally posted by wolfiegirl I tried shooting RAW+ today in an attempt to get both jpg and raw images with the black and white setting. Complete and utter fail. It takes too long to process onto the card, thereby stalling and making my subjects wait too long (4 year olds are notorious for being impatient). I ended up switching the camera off and on again.
If speed is of the essence, I'd always suggest shooting either RAW or JPEG only - not both - and use decent spec SD cards. Although some cards are rated as high speed, I've found quite a variance in how quickly they get up to the specified write speed. Some gradually ramp up to the quoted spec during extended write cycles, whilst others get there almost immediately. The difference in real-world performance can be profound. I use Samsung 16GB UHS1 Pro cards in my Q and Q7 with good success.
Originally posted by wolfiegirl In an attempt to salvage what I had, I had to use the settings you suggested.
They're looking good with a few tweaks here and there for my personal preference. Really appreciate you helping out/sharing and just wanted to acknoweledge your assistance and say thank you again!
You're most welcome
I'm really pleased it got you in the ball-park, and it's great that you've tweaked further to your own preferences. That's what it's all about!
Originally posted by wolfiegirl Interestingly lightroom didn't detect the jpgs at all. I wonder if I'm using the wrong settings.
If you want to be able to import JPEG and RAW from the same source folder (whether on a card or your hard drive), go into Edit, Preferences, General (first tab), and in the Import Options section, tick the option for "Treat JPEG files next to RAW files as separate photos". From then on, whenever you import, you'll see both the RAW and JPEG images on your card.
Originally posted by wolfiegirl Next time I choose to do black and white I think I'll just need to shoot jpg only.
That would work... however, bear in mind that you can use the Smart Effect B&W setting for RAW-only shooting too. The LCD panel will show the B&W image live, but the captured image will be saved as an unprocessed colour RAW, which you can then apply your favourite Lightroom settings to.
Truthfully, for this kind of extreme-processing photography, JPEG is probably more than adequate, as you're really not too concerned about being able to recover shadows and highlights... but out of habit I prefer to shoot RAW so I have as much flexibility as possible in post-processing.
