10-30-2017, 06:12 PM   #16
QuoteOriginally posted by CarlJF Quote
The OP's P&S can do just fine.
Does it have the bokeh of a Q?
10-30-2017, 06:57 PM   #17
CarlJF's Avatar
QuoteOriginally posted by lytrytyr Quote
Why do you care now ? You said in your post above that it's not important...
10-31-2017, 10:27 AM - 1 Like   #18
No, I did not. Please do not misquote me.
The huge DOF of the Q is rather a big issue for a beginner. It doesn't allow one to learn how to control depth of field nor to experiment much with it. Which is a big problem since it's a basic knowledge every photographer must know very well. Not even talking about the many photography styles relying on limited DOF to make their effect, which are simply out of the realm of what can be achieve with a small sensor camera.
And that is what does not match with my own experience of the Q system.
10-31-2017, 11:38 AM - 1 Like   #19
Agree, the Q is enjoyable because making it do what you want is both challenging and attainable.
11-01-2017, 08:19 PM   #20
Sluggo's Avatar
QuoteOriginally posted by henryC Quote
I will consider buying the Q7 if I can find a good deal (Around $230-$250 for a used model, with lens)...
Just a quick followup. Surveying prices on ebay and amazon, it looks to me like all the Q models are more expensive on the used market than they were a year or two ago. It's true even of the older Q/Q10, so I'll withdraw my advice on that score. Good luck with your plans if you haven't already made a purchase.
11-02-2017, 10:51 AM   #21
If you do go for a Q or its' successors, make sure you get one at a good price, and factor in the possible cost of getting the sensor cleaned. You are unlikely to be able to get one unopened in new condition any more, and as the sensor is so small, any dust will show on even small prints. At least it should be a cheap job, as the sensor is accessible, unlike many cameras with retractable lenses, which still let dust get onto the sensor. This is one of the main reason I got my Q, as my beloved Ricoh GRD iv came a cropper to dust.
11-02-2017, 11:39 AM   #22
Cipher's Avatar
The sensor on a Q is easy to clean- a little lens cleaning fluid on a lens tissue, gently wipe it across the sensors's cover glass, using the surface tension of the fluid in the tissue to make contact. Any dust usually blows right off. There are still new Q's in Japan, the Japanese vendors I have used have always been first class, although YMMV.
11-02-2017, 12:35 PM   #23
QuoteOriginally posted by Cipher Quote
Thanks for that info. I will bear it in mind when my Q needs a clean.
camera, costs, dslr, entry, mirrorless, pentax q, pentax q10, pentax q7, photography, q-s1, q10, q7, quality
50-135 2.8 vs 70-200 2.8 Which would you recommend? DawnHoweth Pentax SLR Lens Discussion 32 01-28-2018 08:49 AM
what brand wifi card would you recommend for my K1 ? is there any maz size for it ? brando Pentax Camera and Field Accessories 4 08-21-2017 04:50 PM
What would you recommend? Low light action shots. Is it possible on a TIGHT budget? Shock2DC Pentax SLR Lens Discussion 29 10-26-2016 11:34 AM
Question: would you recommend Pentax to a friend? top-quark Pentax DSLR Discussion 13 10-07-2012 07:24 PM
Which line up would you recommend? axl Pentax SLR Lens Discussion 27 02-12-2010 04:17 AM
All times are GMT -7. The time now is 04:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
