11-06-2017, 08:51 AM - 1 Like   #1
How to disable LCD auto turn off
I am using the Q (first version) mounted on a microscope. And it's quite annoying that if there are no buttons pressed, it decreases brightness then switches off. Is there a menu option to disable it?
11-06-2017, 11:43 AM - 1 Like   #2
Set-up (Spanner) menu 2, Power Saving. Either clear the check box, or change the Auto Power Off setting.
You're gonna need a slack handful of batteries though...
11-06-2017, 01:56 PM - 1 Like   #3
Sluggo's Avatar
QuoteOriginally posted by Shedking Quote
Or if it's indoor use, try an AC power supply that connects to the battery slot. This one is marketed for Fuji compacts but I found it works on the Q.
11-09-2017, 01:20 AM - 1 Like   #4
Thanks, strangely only after your answer I was able to find it.
Actually taking time to half-press shutter to avoid camera getting in standby mode wastes more than this feature ever saves.
11-09-2017, 02:42 AM - 1 Like   #5
QuoteOriginally posted by alliumnsk Quote
I face exactly the same issue when attempting to manual focus a lens on the genuine Q/K adapter. By the time I've stopped down after focusing, the viewfinder has usually dimmed itself.
11-10-2017, 01:46 AM   #6
I truly hate the auto dim feature. So glad it can be shut off.
Q on a microscope sounds interesting. Care to provide any details?
Thanks,
barondla
11-13-2017, 03:36 AM - 1 Like   #7
it's rather crude thing with RMS mount, I use M39 adapter and some duct tape to attach the Q in place of eyepiece.
11-13-2017, 07:31 AM   #8
Alliumnsk, still sounds great. Lack of shutter vibration should to be a plus on a microscope. Love to see some of your results one day.
Thanks,
barondla
camera, lcd auto, mirrorless, pentax q, pentax q10, pentax q7, q-s1, q10, q7
Can you turn off lcd? tgchan Pentax K-1 3 08-16-2017 05:35 AM
Pentax K-50: How to turn off the LCD screen? techlady Troubleshooting and Beginner Help 6 03-29-2017 07:19 AM
Nature ...there is a season, turn turn turn... littledrawe Post Your Photos! 4 09-19-2012 11:57 PM
LCD turn off option. ricardsonwilliams Pentax Q 4 03-05-2012 10:43 AM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
