Originally posted by 2old4toys Interested to know why you ask this. I do find the Q camera body adds some colour changes to the final image knowing it’s mounted with an 07, vs no lens at all. So the PCB does do something.
The Q can only do 2 second exposures with adapted lenses, but 16 second exposures with stock lenses. Elsewhere on this forum it’s argued that it’s because the stock lenses have a shutter, which doesn’t make any sense because the electronic shutter has to act in conjunction with the mechanical shutter anyway. If the mechanical shutter is held open for 16 seconds, the electronic shutter needs to be “held open” for 16 seconds too.
(Hmm… The 07 lens doesn’t have a shutter, what’s the maximum exposure time with it?)
So then I got to wondering, how hard would it be to make an adapter with a little board that spoofs the lens type?
Seeing the PCBs out of multiple lenses will give me an idea of what the pins might do, and what kind of electronics are attached to the pins. The body cap lens would be a great specimen because it’s so simple. Looking at photos of the rear of the stock lenses, I can see that 3 or 4 of the pins are probably used as part of some simple “short the pins together” coding system, but the rest are a mystery.
I’ve ordered a cheap extension tube that I will be able to modify to intercept the electrical signals between the camera and a lens and then feed them to an oscilloscope or logic analyzer.
I also found a broken 06 lens that can’t focus, which seems to be a common mode of failure for that lens. I’ll try to fix it, but my primary goal is to have a lens a I can fearlessly dissect.
