04-01-2018, 09:47 PM   #1
Pentax Q and 55-300 PLM?
The KAF4 mount doesn't seem to have an aperture lever, does that mean it can't be stopped down with the official Pentax adapter? I am about to buy a WR 55-300 but, it looks like I need the non-PLM if I want to use it occasionally with the Q.
04-01-2018, 10:00 PM   #2
QuoteOriginally posted by CheepShot Quote
That's correct. Also, the the lens needs power in order to be able to focus (manually), so it would pretty much be useless when adapted.
Still consider if it's worth sacrificing that ultra fast AF for adaptability.
04-01-2018, 10:09 PM   #3
Thanks! Tough decision.
04-01-2018, 10:59 PM   #4
The WR 55-300 was a great lens for what it cost me. I would totally go that way. The screw drive can be loud though, so that might be a consideration. It didn't bother me much though. Only when trying to shoot birds was it ever really a noticeable issue. In that case I just prefocused and tapped the AF to lock it in. The speed on that lens on screw drive and a K-3 easily crushes my 60-250 into the dust. The 60-250 is painfully slow at times. I gotta be honest. I don't think you will get super great results from the 55-300 and the Q. The 55-300 is pretty sharp, but not really on the level of the 60-250 which, wide open is also not ultra sharp, but very, very usable for portraits. I liked the 60-250 wide open more than the 55-300 which will run into diffraction at the long end on the Q wide open. I know this muddies the water but it seems that only the best primes really are passable on the Q adapter. The results I have seen from zooms were generally less than stellar.
04-02-2018, 10:32 PM   #5
QuoteOriginally posted by zosxavius Quote
Thanks for the tip. I'll probably buy the PLM and keep watching for a 300mm DA.
04-03-2018, 06:52 PM   #6
retired sw engineer
reh321's Avatar
When I first got my Q-7 three years ago, I did some backyard testing with five different lenses, lenses I had acquired over the years that all went to 300mm. Based on that testing, I ended up using the Sigma lens with my Q-7 and the Pentax WR lens with my K-30. A Q-mount camera and a K-mount camera make different demands on a lens, so we really shouldn't expect one lens to be best in both settings. Apart from being willing to use two different lenses, you may have to be willing to compromise.
Of course, the best solution would be a native Q-mount 55-300mm lens, but I've given up hope on that one.
04-04-2018, 09:04 AM   #7
QuoteOriginally posted by reh321 Quote
Which Sigma were you using with the Q?
04-04-2018, 08:14 PM   #8
retired sw engineer
reh321's Avatar
Sigma 70-300mm f/4-5.6 APO DG
adaptor, camera, kaf4, mirrorless, pentax, pentax q, pentax q10, pentax q7, plm, q-s1, q10, q7
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? Bui Pentax SLR Lens Discussion 67 06-25-2018 08:15 PM
FA 100-300 vs Pentax 55-300 PLM bscott Pentax SLR Lens Discussion 6 11-18-2017 07:27 AM
DA 55-300 vs 55-300 PLM John A. Pentax SLR Lens Discussion 18 11-03-2017 06:18 AM
55-300 PLM or non-PLM version to K-1? Vignetting etc? HankVonHeaven Pentax SLR Lens Discussion 7 01-29-2017 09:54 AM
18-135 or new 55-300 PLM as an WR upgrade for old DA 55-300 - HELP :) gelokrol Pentax SLR Lens Discussion 6 12-15-2016 11:53 AM
All times are GMT -7. The time now is 05:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
