Show Printable Version 84 Likes Search this Thread
07-04-2018, 12:42 AM - 3 Likes   #16
Pentax MX-1, Q, Q10, Q7, QS-1 CMos sensors...
QuoteOriginally posted by 2old4toys Quote
@geo444 am I looking at this right that the bigger Q7 sensor is actually “less” sensitive than the smaller Q10 ?
Hi 2old4toys, what we know for sure is :
- Selecting Pentax 1/2.3 + 1/1.7 sensors in DxoMark DataBase we see
the 1/1.7" sensor has a 208 DxoISO score instead of ~280 as it's 50% larger than the 1/2.3" in the Q, Q10 :
Verification of the Direct Relationship from Sensor Area to DxoISO all other things equal
( Pentax Q + Q10 DxoISO = ( 183 + 189 ) / 2 = ~186 )
Can't go deeper with DxoMark as they didn't Test the Pentax Q7 & QS-1 :
My Comment on " DxoMarketing " : http://disq.us/p/1nnzyyb
- if the 1/1.7" sensor had the Starvis-Score of the 1/2.3" sensor
it should have a : 208 * 3354 / 2454 = ~284 DxoISO !
Starvis-Score & DxoISO seem Correlated
Do we place the QS1 as the same with the Q7 and the Q at the same place as the Q10 ?
A CMos Sensor is a Highly Programmable Device, so
the only way to know What's the Sensor inside a Camera is to
look inside the FirmWare with an Hex-Viewer by downloading an Update
here is an example with the Q10 FirmWare
Verification of the imx078cqk
see attachment
07-07-2018, 02:51 AM - 1 Like   #17
0.666 Devil's Speed Booster 4 Pentax Q... + Mechanical Shutter !
2) allows longer than 2s exposures (up to 30s !) and bulb mode for 30s exposures.
Note: 0.666 Devil's Speed Booster 4 PQ to Nikon F will do the job as well
This would be Very Useful for Astro-Photography...
the SkyWatcher 254/1200 is a very affordable Excellent f/4.7 Newtonian...
with 0,666 Devil's Speed Booster 4 Pentax Q it would become
2.8x 1200mm = ~3360mm at f/2.4 to Overcome the 30 sec. limitation of the Q !
Even if lowering the ISO setting down to ISO 800 !
- all my Galaxies & Nebulae were shot with the Q10 at ISO 1600 at f/5 :
Photos tagged with "iso-1600": Galleries: Digital Photography Review = geo444
which is a little too much to avoid the +30sec-LENR* when Temperature is over ~24°C
+30sec-LENR = in body Dark Frame subtraction
No Need to implement a Physical Mechanical Shutter inside the 0.666 DSB4PQ...
just make believe the Pentax Q "there is a Mechanical Shutter in the 0.666 DSB4PQ",
because for Astro-Photography there is No Need of a Physical Mechanical Shutter...
but just : Start / Stop Exposure... Build Raw File... Write Raw File on the SD card !
In fact, make believe the Pentax Q "there is a Mechanical Shutter in the 0.666 DSB4PQ",
just means (x?) Electronic Contacts that respond with the Correct Voltage when required
Who has some knowledge about the Protocol between the Body and the PK-Q Adapter ?
- just for the specific part "is there a Mechanical Shutter in this Adapter" ?
what do you think about that 2old4toys, AstroDave, Mikesul, Barondla, others ?
an affordable ~3360mm at f/2.4 for our Pentax Q ?
07-08-2018, 09:32 PM   #18
QuoteOriginally posted by geo444 Quote
I can’t contribute to how it would be done but a firmware hack would be the most elegant solution to allow bulb mode and timed exposures up to,or even beyond 30s for any lenses/adapters without leaf shutter mechanics.
Is a leaf shutter even any use at all on Astro? Probably want to use electronic shutter for saving on unwanted vibrations anyway is my guess. Just want the longer than 2s exposures to be unlocked.
More realistically, can we currently connect the Pentax PK Q adaptor to a telescope today?
Like this Adapter For T-Mount T2 Telescope Lens to Pentax K PK K3 K50 K5 IIS KS1 KS2 https://www.amazon.com/dp/B074FRWDFN/ref=cm_sw_r_cp_api_scVqBbB64WE3C
So at least we have Q connected to a telescope with bulb mode using an IR remote?
Also any way to skip the dark frame collection on a Q?
07-09-2018, 01:16 AM - 1 Like   #19
Pentax Q minutes Exposures : FirmWare Hack ?... or 0.666 DSB4PQ ?
I can’t contribute to how it would be done but a Firmware Hack would be the most elegant solution to allow Bulb mode > 30s
Is a leaf shutter even any use at all on Astro ? Probably want to use Electronic Shutter for saving on unwanted vibrations anyway is my guess. Just want the longer than 2s exposures to be unlocked...
Hi 2old4toys !
A FirmWare Hack was my 1st idea years ago, so I managed a Q10 FirmWare Disassembly to begin with
Many thanks to Acade for his tool : http://acade.au7.de/disasmips/disasmips.htm
I totally succeeded in that huge work inside the Q10 FW :
Files, Functions Statistics, Call Statistics, Symbol Map :
+ 0268 HTML Files : Calls are hyperlinks
+ 2886 Total Functions
+ 3197 Call Targets
+ 1185 Map Symbols
= 130 MB of Files to work with... that I will email to every FirmWare Hacker who asks for
Just remember it's a MIPS RISC Processor inside the Pentax Q(x) !
A " C " De-Compiler would have been more useful in issuing " Friendly Readable " Smaller files...
But I never could find a " C " or " Pascal " De-Compiler tool for free ?
Who knows one that reads MIPS objects ?
The reason why Electronic Shutter Exposures are limited to 2 sec....
is the same that ISO 6400 Max Exposure is 2 sec.
= Noise increase !!
Electronic Shutter on a CMos sensor needs More Transistors at work for Each Pixel !
Here they are 12.4 Million Pixels on a 4.6 x 6.15 mm IC...
thus the Noise increase !
...More realistically, can we currently connect the Pentax PK Q adaptor to a telescope today ?
So at least we have Q connected to a telescope with Bulb mode using an IR remote?
Also any way to skip the Dark-Frame collection on a Q ?
More simply, one could use a (PK to) T2 Adapter, as I do...
... But that Won't upgrade your Telescope up to a ~3360mm f/2.4 Newtonian
to Overcome the 30 sec. limitation of the Q :
https://www.pentaxforums.com/forums/136-pentax-q/369368-pentax-q-astrophotog...ml#post4351053
The IR Remote won't work in Bulb mode on Pentax Q :
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/274316-pentax-h...ml#post2957675
No Way to skip Random-Dark-Frame Subtraction if Ambient Temperature reaches ~25°C
... or if you've just over-used the Live-View for framing & focusing !
unless returning to the FW Hacking solution...
07-09-2018, 08:04 PM   #20
Just checked... the IR remote works for bulb mode on my Q-S1 but sure enough... not available on my original Q.
@geo444 BTW your pics nebula and galaxy shots make me nostalgic for 80’s sci fi TV intros like Buck Rogers and Battlestar Galactica from my childhood. How did you trigger these 30 second exposures rigged to your telescope if done without IR?
07-11-2018, 12:44 PM - 3 Likes   #21
Q10 AstroPhotography in " Lucky Imaging " mode !!
How did you trigger these 30 second exposures rigged to your telescope if done without IR ?
So Pentax achieved a tiny progress on the Q-S1 FirmWare... just before the extinction of the Q family...
I set the 30 sec. exposure in Manual Mode which works from the IR Remote !
Not many Science Fiction among TV programs when I was young... but...
I have read many Short Stories coming from "Weird Tales" and compiled into the French Mag. "Fiction"
My favorite author was " Theodore Sturgeon " !
What's really missing in Science Fiction literature...
... no one has never predicted we could get amazing Astro-photos from...
such a tiny camera as a Q10 !
Pentax Q10 Lucky-Imaging on M-57 = 108 x 2 sec. subs + 68 x 1 sec. exposures, ISO 6400 all
DeepSkyStacker in Super-Pixel Mode* ; Down Left is a 100% crop of M-57
Some details missing because NR can't bet set Off !
Right click View-Image to Download :
Super-Pixel Mode = No Interpolation, Pixel Color is taken from 2x2 Pixel RGGB matrix :
DeepSkyStacker - Technical Info
Resulting image Area = initial RAW Area / 4 !
Just found back the copy of DSS parameters before Stacking, see attachment ->
= only 4 min 44 sec total exposure !
Enjoy this tiny Pentax Q10 that no Science-Fiction never predicted !
07-11-2018, 11:11 PM   #22
Impressive astrophotos! You are getting amazing results with the Q10. Makes me want to give this a try.
Thanks for sharing,
barondla
07-13-2018, 08:04 AM - 2 Likes   #23
Pentax Q10 AstroPhotography in « Lucky Imaging » mode !
QuoteOriginally posted by barondla Quote
Impressive astrophotos ! You are getting amazing results with the Q10....
Thanks Barondla !
The Results are exactly as Good as expected in my Starvis-Score ranking...
... Makes me want to give this a try. Thanks for sharing,
barondla
You won't be disappointed !
In case, I'll give you all the tips that greatly improve these Q(x) for Astro-Photos :
- how to Remove their IR-Cut filter w/o disassembling
- how to fit a Standard 1"1/4 Filter inside their Pentax K4Q Adapter
- how to make your EQ Mount Steady as a rock !
- how to prevent Sensor Heating, so LENR
- how to avoid Light Pollution Filter
- etc, etc...
LENR : Long Exposure Noise Reduction,
generally a Dark-Frame subtraction Doubles the Exposure
+ Smoothing NR increases
Messier-57 Ring Nebula, apparent size 1 x 1,4 arc-minute, 2300 L-Y from Pentax Q10
Pentax Q10 Lucky-Imaging on M-57 = 108 x 2 sec. subs + 68 x 1 sec. exposures, ISO 6400 all !
DSS set to Standard Bilinear Interpolation ; Down Left = 100% crop of M-57
Just imagine how fine and sharp details and stars would be...
if I were Not at Marseille with such an Agitated & Turbulent Atmosphere ?
Here are only 4 min 44 sec total exposure !
07-13-2018, 08:52 AM - 1 Like   #24
- etc, etc...
I would love to know all about the above!
07-16-2018, 02:01 PM - 2 Likes   #25
My Site to improve (DIY) your Pentax / Samsung "Astro-camera" !
My Site to improve (DIY) your Pentax / Samsung "Astro-camera" :
Electro-Opto-Mechanical easy Mods to improve your Pentax, Samsung "Astro-camera"
I'll have a hard-working August month to fill this Site !
- hundreds of text lines to write...
- tens of photos to well illustrate the text above...
- tens of verifications to see what happens if a beginner just applies this...
I would love to see yer Astro-photos after DY all these improvements to yer Pentax / Samsung !
From now, Budding Astrophotographers are not going to stay "Beginners"
The link had a bug (?), now it works fine, enjoy
Site : mecastronics.free.fr
07-16-2018, 09:47 PM   #26
Geo444, neither link seems to work on my Amazon Fire tablet. I get "This site can’t be reached
mecastronics.free.fr’s server IP address could not be found."
If my tablet is causing the pain, I will fire up the laptop. Interested to see your Q mods.
Thanks,
barondla
07-16-2018, 10:43 PM - 1 Like   #27
Thanks, barondla
Many Thanks for your interest Barondla !
I think maybe it just takes time to be available over the whole www ?
On one of my PCs, I just got it only after midnight here ( Paris Summer Time ) !
Yesterday, I thought it had a "Bug", but couldn't find any...
Another indirect Acces could be Via the free.fr Site-Data-Base :
Googl' this : pagesperso.free.fr/Sciences/Astronomie
Choose : Résultats par page : 50
Select : Evaluation Visiteurs Ascendant, then clic on the '>'
Go to Page Bottom and clic on Page #9
It's on the 7th last line : mecastronics Ajouté le 17/07/2018
or on the right side : http://mecastronics.free.fr
At this time, even Googl' ignore my site !
Wait & see...
PS :
Last Nights : Strict Application of all the Tips in my site improving the Pentax Q10's IQ :
= No Light Pollution Filter > ISO 800 at F4.7 on the Skywatcher 254/1200
But Huge Turbulence : +50% of the DNGs were discarded
- only 44 x 30 sec. ISO 800 on Messier-27
not so bad for only 22 minutes of exposure ?
... except some inflated stars !
eqv FL 6720mm
Now imagine the same work on a ~3360mm at f/2.4 :
07-21-2018, 04:25 PM   #28
or on the right side : Electro-Opto-Mechanical easy Mods to improve your Pentax, Samsung Astro-camera
Wait & see...
PS :
eqv FL 6720mm
Pentax Q for astrophotography beginner? - Page 2 - PentaxForums.com
Geo44 found your site. It talks about the Q, K5, etc. But when I click the links there is no info about tips or mods. The page just sits there. The only links that work are the photo gallerys. Is the site under construction and not quite ready yet?
Thanks,
barondla
07-23-2018, 02:11 PM - 1 Like   #29
kwb
Hey geo444, I just wanted to tell you that I'm REALLY interested to see your tips! Take your time but keep us posted!
07-24-2018, 02:13 PM - 2 Likes   #30
I'll have a hard-working August Month to fill this Site !
I forgot the 2 Sensitivity Tables to summarise all I've written here and there on forums...
Maxi Astro (Ciel Profond) au NX mini...
= Nights & Days to gather, write and verify everything...
+ it's my first HTML Tables !
Geo44 found your site. It talks about the Q, K5, etc. But when I click the links there is no info about tips or mods. The page just sits there. The only links that work are the photo gallerys. Is the site under construction and not quite ready yet ?
Thanks, barondla
Hi Barondla : I was just working hard on it !
Now do you see 1 Page with the 2 Sensitivity Comparison Tables : ISO/mm˛ + mV/µm˛ ?
DIY pages will come next...
QuoteOriginally posted by kwb Quote
Hey geo444, I just wanted to tell you that I'm REALLY interested to see your tips !
Take your time but keep us posted !
Thanks to support my Site Kwb !
If you find discrepancies or errors or whatever seems obscure : Please to report it here in this thread !
Thanks, now it's time for me to sleep zzzZZZzzzZZZ...
camera, fire, midnight, mirrorless, pentax, pentax q, pentax q10, pentax q7, q-s1, q10, q7, summer, tablet, time
Astrophotography + SMC Pentax-FA* 24mm F2 AL [IF] bnhoj Pentax SLR Lens Discussion 17 10-26-2019 08:45 AM
Landscape/Astrophotography lenses for Pentax K-30 tigerz1995 Pentax K-30 & K-50 2 02-18-2018 08:25 AM
Pentax 20mm f2.8A or Lawoa 15mm f4 for Astrophotography? stemked Pentax K-1 & K-1 II 3 05-04-2017 07:49 PM
Pentax 300mm lenses for Astrophotography LennyBloke Pentax SLR Lens Discussion 7 09-09-2016 09:23 AM
Beginner photographer, beginner with Pentax W.Scott Welcomes and Introductions 11 05-11-2014 11:44 PM
All times are GMT -7. The time now is 11:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
